Author Topic: question on truck beds!!  (Read 14107 times)
Offline okiesinmt
« on: April 20, 2010, 11:00:45 pm »
Will any year bed from 73-87 fit on all the chasis from those years?  Are they all interchangable or will some work for certain years?
Mine is a 75 short bed, very rusted looking for something easier to start with.
Thanks,
Sean
Offline 80stepsideguy
Re: question on truck beds!!
« Reply #1 on: April 21, 2010, 03:01:50 am »
Yes 73-87 will all work prefectly...
thanks
pat
1998 Chevy 1500 S/B 2wd
« Reply #2 on: April 21, 2010, 03:29:00 am »
There are minor differences but they'll all interchange. Fuel fillers changed, tail lights on stepsides, and tailgates changed designs and hardware over the years.
Offline okiesinmt
« Reply #3 on: April 21, 2010, 01:39:05 pm »
Thanks,
Sean
Online Captkaos
« Reply #4 on: April 26, 2010, 11:29:34 pm »
Just adding info to the post but on LWB's the bolt hole locations changed.
Offline Lucky73
« Reply #5 on: April 27, 2010, 11:55:54 am »
Really.How? ???
73 Chevy C10
73 GMC K20
93 Chevy S-10
Online Captkaos
« Reply #6 on: April 27, 2010, 02:41:45 pm »
The second set is in a different location.  (spaced further.)
Offline jcfisher
« Reply #7 on: May 14, 2010, 11:49:20 am »
I agee with capt. and can attest to it with my '76.  My bed was ruined by a friend who drove it thru a stop sign.  I replaced the bed with one from an '84 chevy.  It was almost perfect, no rust, no dents, etc.   But, two of the mounting holes dont line up.  So it is bolted down with 6 of 8 bolts.  I still haven't drilled the frame for the other 2 holes, but in time i will.
« Reply #8 on: May 14, 2010, 05:22:31 pm »
My 74 Bed bolted right onto my 87 frame. All the holes lined right up.
Offline Bitzer!
  • Smiles per gallon
« Reply #9 on: May 25, 2010, 02:49:23 pm »
Hey wouldn't it be easier to drill up through the frame using the original holes and make new holes in the bed rather than vice versa?
1979 GMC CrewCab  C20 1t
Offline three8six
« Reply #10 on: May 25, 2010, 03:03:14 pm »
Yes if you would be ok with an empty set of holes in your bed. I do know they are trucks, but I sure would try to avoid drillin holes in my sheet metal.
« Reply #11 on: May 25, 2010, 04:47:34 pm »
I'm confused here as I've never had a one not match up. Where exactly is there a difference and what year is this change?
Offline Bitzer!
  • Smiles per gallon
« Reply #12 on: May 26, 2010, 08:06:18 am »
Personally I'd use the original frame holes and drill new into the bed, far easier than trying to re-drill the frame. As for the "old" holes in the bed, I'd drop short bolts through to make it "look" like they should be there so no holes would be seen  ;)
Offline ccz145a
« Reply #13 on: May 26, 2010, 01:12:49 pm »
The holes do not line up when you put a newer bed on an older frame. the two sets of bolts at the back are fine, the front set closest to the cab is fine, it is the second set back from the cab that are different.
« Reply #14 on: May 26, 2010, 03:54:31 pm »
I'm curious as to why I've never run into that problem and I just put my original 74 bed on an 87 frame.
