Author Topic: AC compressors  (Read 23120 times)
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
AC compressors
« on: April 22, 2010, 07:21:48 pm »
well my AC compressor finally crapped out after 32 years of use and an r-134 conversion 3 years ago.  so my question is, when I fix it, should i just get another compressor like i have now (the big long one 1978 model)  or would it be worthwhile to get a setup for a newer model like my my 87 had?   would it save me some mileage or is it even worth the bother of new brackets, hoses, etc...
Right now I'm thinking to just replace what I have with the same thing.  I need to get it fixed because I get BETTER mileage on the highway with the windows up and the ac on NORM, than using the 70mph AC.  Plus the window tint don't keep the sun out when its rolled down.. ;D
Re: AC compressors
« Reply #1 on: April 22, 2010, 10:21:09 pm »
Just get another A6. If it puked though, make sure you replace the acuumulator and orifice tube. Flush everything else out.
  • Z62 ON-ROAD
Re: AC compressors
« Reply #2 on: April 23, 2010, 10:43:24 am »
Okay.  Thanks!
Offline SMiller
Re: AC compressors
« Reply #3 on: May 05, 2010, 10:52:56 pm »
I find myself in the same place, I bought my truck over the winter and I see it has a newer reman compressor and it wouldn't kick on so I had it filled and it was ice cold for a week or two, I popped the hood the other day to see green freon everywhere. Now I am wondering if I should go ahead and do a serpentine swap or put another reman compressor on it. I know the serpentine swap uses the late model compressor. I wonder if it will blow as cold or colder with the later compressor? The truck has already been converted to 134.
Offline ccz145a
Re: AC compressors
« Reply #4 on: May 06, 2010, 09:12:25 am »
I assume the leak is at the compressor? I always thought the smaller compressor moved more fluid with less power. So it should be the better choice.
Offline bobcooter
  • 1979 Scottsdale C-20
Re: AC compressors
« Reply #5 on: May 06, 2010, 03:34:47 pm »
The smaller compressors are cheaper than the old A6's new. A new A-6 is around $400.00 but a remanned one is only around $130.00 at O'Reillys. Just replaced my old A-6 with a reman, replaced the suction and discharge hoses, replaced the dryer, pressure switch and orifice tube and had to have a new liquid line made up at a local shop, plus my 134a for under $400.00. Now I'm cruisin' cool!
Re: AC compressors
« Reply #6 on: May 06, 2010, 03:59:31 pm »
A question my 94 after the wife wrecked it about in 04 well we got a 91 font clip and the condenser won't mate up to the hoses do to it being r12 so its been open since the crash and I want to get it going again what's the best way and cheapest way to do it ex. Would I flush the parts and put a new orifice tube in and replace the condenser but I'm thinking what about parts going bad. Another thing I was thinking would it be better to get them from the yard from a closed system
Re: AC compressors
« Reply #7 on: May 06, 2010, 11:36:59 pm »
The acuumulator has a desicant bag (silica gel) that absorbs moisture. Like that little package in your beef jerky that says do not eat. That needs to be replaced if the system has been left open.  Everything else can be flushed and vacuumed.
Re: AC compressors
« Reply #8 on: May 06, 2010, 11:42:56 pm »
You mean that little bag not spices?  ::) lol. Thanks that kind of saves me
Offline Grover 1
Re: AC compressors
« Reply #9 on: May 07, 2010, 01:11:17 am »
Oh man, you mean we're not supposed to eat that??  I always thought that was the best part.
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
And here I sit so patiently
You have to pay to get out of
Re: AC compressors
« Reply #10 on: May 07, 2010, 07:37:10 am »
If you eat it it will absorb all of the juice in your body and you will shrivel up into a raisin
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: AC compressors
« Reply #11 on: May 07, 2010, 12:34:54 pm »
they might come in handy if you want to avoid a DUI
Re: AC compressors
« Reply #12 on: May 07, 2010, 02:10:00 pm »
Just puke everywhere - then they won't give you the breathalizer
Re: AC compressors
« Reply #13 on: May 19, 2010, 07:00:09 pm »
Hey vile how far is the orifice tube supposed to be in the condenser
Re: AC compressors
« Reply #14 on: May 19, 2010, 07:09:35 pm »
The orifice tube isn't in the condenser. If it is you're in trouble! It's in the line going to the evaporator. You can see slightly after the nut dimples in the pipe.
