Author Topic: cam & head help  (Read 5020 times)
Offline KoolerSL2
  • Chevy / Ford: A house Divided
cam & head help
« on: April 23, 2010, 09:09:50 am »
hey guys i know its been a long time.
but motor is coming out soon and im needing some help trying to find a cam thats gonna hold up...
called Comp direct and can get a custom ground hyd roller cam & lifters for $250.
but with the valve springs im running i dont know if it'll hold up either.
is there a way to measure my valve spring pressures and such without full disassembly of the heads?
and next question is if i go solid roller ( which lookds to be what im going to have to do ) how well do most of them hold up on the street?
1985 C10 LWB: gone but never forgotten
1987 R10 LWB: 107k mile near original survivor
2020 Mustang GT: 6sec 1/8mi driver
https://m.facebook.com/pages/category/Automotive-Customization-Shop/HPR-105373468425153/
Re: cam & head help
« Reply #1 on: April 23, 2010, 09:25:20 am »
Is this a roller block? If not you'll need retrofit rollers, different pushrods, a method of limiting cam thrust, distributor gear, and springs matching the cam specs. If it's a small base circle cam you need to be careful too as the lifter will travel further down in the bore. Is this a stroker? Personally I would run a hydraulic roller.
AS far as testing your valve springs, I would check them uninstalled on a valve spring tester. This is the one I use
Any machine shop should have one, you could bring a spring down to them.
Offline KoolerSL2
Re: cam & head help
« Reply #2 on: April 23, 2010, 10:31:42 am »
it is a 91 model block.
its got the bosses made for the roller spider.
just need to be drilled and tapped.
Re: cam & head help
« Reply #3 on: April 23, 2010, 07:07:49 pm »
You won't need anything fancy then. Use the stock dist drive gear. I just used this cam for an engine I'm building.
http://www.summitracing.com/parts/HRS-180235/
Offline team39763
Re: cam & head help
« Reply #4 on: April 23, 2010, 07:52:55 pm »
I know a bunch of guys down here that run solid rollers on the street and have been for years.  I guess it's all in the setup...making sure you got good valvetrain geometry to begin with and then maintaining it.  I do know that a lot of guys don't recommend it though.
Re: cam & head help
« Reply #5 on: April 23, 2010, 08:39:57 pm »
It's more noisy and annoying than anything. I wouldn't run one in even a weekend warrior. Something for the strip is a different story
