Author Topic: Radiator petcock  (Read 5871 times)
Radiator petcock
« on: May 01, 2010, 04:13:47 pm »
I am going to install a new aluminum radiator in my truck. I was thinking of replacing the petcock with something else, since coolant gets everywhere when draining it with the petcock. The steering gear box is right in the way of using a funnel.
Has anyone used anything different, or found a good way of funneling the fluid better?
Re: Radiator petcock
« Reply #1 on: May 01, 2010, 11:09:12 pm »
I generally slip a 3/8" fuel hose on the end when draining them.
Offline joesgarage71
  • Wrench
« Reply #2 on: May 02, 2010, 04:19:56 am »
 I don't bother with the drains, I got a big pan and just take the lower rad hose off.
« Reply #3 on: May 02, 2010, 09:22:20 am »
I also put a hose on the end of it.
« Reply #4 on: May 03, 2010, 02:45:25 pm »
Do you just hold the hose there? There is nothing for the hose to slip onto.
Offline jaredts
« Reply #5 on: May 03, 2010, 03:15:07 pm »
Go look at replacement petcocks.  Some of them have around a 3/8" diameter barrel.  Right after I bought my truck it was idling in my driveway and suddenly the petcock gave out and hot coolant went spraying everywhere.  I only missed getting hurt by a few seconds as I was just looking down in that direction.  After draining my coolant and removing the petcock I was surprised to see it looked undamaged.  For years I had a replacement in my toolbox for just such an occasion.  The one I took out had nothing for a hose, but the replacement did.
« Reply #6 on: May 03, 2010, 03:18:52 pm »
OK Ill search for one. I wasn't sure they were available. Ive never seen one on any of my vehicles. Thanks!
« Reply #8 on: May 03, 2010, 06:21:13 pm »
Awesome, thanks!!
