Author Topic: replacement upper ball joint torque specs  (Read 6247 times)
Offline chronos
« on: May 03, 2010, 08:33:37 am »
Is there any torque value to installing the new upper BJ?
I'm talking about the 4 nuts that hold it in in place of the factory rivits
Thanks
Offline bgctrading
Re: replacement upper ball joint torque specs
« Reply #1 on: May 03, 2010, 05:52:55 pm »
The 4 nuts should be fairly tight I dont know the exact torque but they are usually lock nuts so they dont back off. The ball joints should have the torque spec in the direction book that came with your ball joints because I have seen Moog and masterpro parts be different specs with other ball joints.
« Reply #2 on: May 03, 2010, 06:02:28 pm »
year make model?
Offline chronos
« Reply #3 on: May 04, 2010, 08:12:53 am »
Sorry , its a 86  1/2ton 2WD
