Brakes and Braking Systems
hard brake pedal, seems no power assist - bad booster?
Topic: hard brake pedal, seems no power assist - bad booster? (Read 9535 times)
fbody
May 07, 2010, 08:17:43 am »
Well, when i got the truck, it had what appeared to be no booster assist on the power brakes. I replaced the booster with another (used) from a guy who said it worked fine, but again used part. I have replaced the master cylinder, bled it first on the bench, no issues. The brake pedal still requires that I press way too hard to stop the truck. Pedal doesn't go to the floor or anything.
check valve, that simple? or still is the booster prob and I should buy new. No leaks anywhere.
73 C20, 3/4 ton.
any thoughts? thanks.
Re: hard brake pedal, seems no power assist - bad booster?
May 07, 2010, 02:10:59 pm »
Pump the brake and hold pressure on the pedal. Start the engine. The pedal should drop. -Report
fbody
May 08, 2010, 11:03:10 am »
pedal doesn't drop at all. pumped it, held it down, started it.. pedal didn't move. i guess that means booster?
malibu795
May 08, 2010, 12:14:39 pm »
check vaccum lines from carb to booster -report
adam wildman
75 K25 383/400
fbody
May 08, 2010, 04:16:28 pm »
yep, plenty of vacuum. pull line, plug it with a bolt, start engine. pull bolt, plenty of vacuum, just about dies.
May 08, 2010, 04:57:01 pm »
Replace the booster if you have vacuum at the check valve.
fbody
May 14, 2010, 09:42:01 pm »
yep, replaced booster tonight, that was it. no more rock hard pedal. Back to power brakes. thanks again.
May 15, 2010, 12:47:21 am »
a question about boosters didn't see the need of adding another post but theres not supposed to be a gaskey between the master cylinder and booster right?
fbody
May 15, 2010, 09:10:12 am »
there wasn't on mine.. and one didn't come w/ the reman booster either.
May 15, 2010, 09:12:37 am »
I didn't think so lol mine was sucking in air there so my booster is bad but I got some gasket seal in there for now rigged her right up lol
