Author Topic: Rams Horns Manifold  (Read 7646 times)
Offline Grover 1
Rams Horns Manifold
« on: May 07, 2010, 10:53:44 pm »
I'm thinking of going to some old school rams horns exhaust manifolds on my 78, also intake manifold oil filler tube and old school orange valve covers.  Any pros or cons regarding the manifolds.  I think changing plugs would be easier than headers.  Am I going to lose much performance, cool sound or what.  Also anyone know of a way to coat them so they stay looking nice, ceramic?
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
And here I sit so patiently
You have to pay to get out of
Offline joesgarage71
  • Wrench
Re: Rams Horns Manifold
« Reply #1 on: May 08, 2010, 09:49:00 am »
You might want to do a search
« Reply #2 on: May 08, 2010, 09:53:24 am »
Any pros or cons regarding the manifolds.  ?
I don't think those manifolds will clear the frame
Offline Grover 1
« Reply #3 on: May 08, 2010, 10:41:20 am »
I did a search and nothing came up
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
Offline Josh454
« Reply #4 on: May 08, 2010, 03:53:12 pm »
What's your engine specs?  If it's a stock style engine, you would probably like the bolt and forget way that manifolds work.  If you are looking to extract every ounce of power out of it then you will want to go with headers.  But you will have to deal with replacing gaskets, rusting out tubes, difficult to get to spark plugs and starter wires.  From what you were describing your setup is, I would personally go with manifolds.
« Reply #5 on: May 08, 2010, 04:50:19 pm »
You only have to worry about replacing gaskets, rusted tubes and the difficulty of getting to spark plugs and wires if you buy cheap headers.
« Reply #6 on: May 08, 2010, 04:53:24 pm »
I would rather headers any day. But eastwoods sells a manifold paint that I've heard is good. Also check out what bill hirsch sells http://www.hirschauto.com/
« Reply #7 on: May 10, 2010, 04:55:11 pm »
Depending on what they came out of they should fit.  I think N2TRUX is running some.
  • Wrench
« Reply #8 on: May 11, 2010, 01:09:12 pm »
 Capn didn't he have to clearence the motor mounts? maybe he'll chime in
