Author Topic: my 75 K20 upgrades  (Read 22156 times)
Offline malibu795
my 75 K20 upgrades
« on: May 09, 2010, 09:44:59 pm »
bough the truck in oct 08
minus then tires this is what it look liked.
originally came with a 350/th350/np203.. 350 came out in went a built 383 wiht a built th400 and B&M holeshot 2400 convertor
currently running 285/75/r16 on 16x7 ford rims..  will be getign some 35x1250x16once then 285 are worn out
recently have ordered/installed/modified
rear shackle flip kit ~4" raise
B52 fornt hangers form DIY4x4
russel -3/-3 26" ss braided line
D60 with ORD cross over
ORD steering brace
right now i am waiting to get new bushing pressed into my 52 4+1 spring packs then they will be installed on the truck.
i am also lookign for a 2wd steering box might buy one straight out.
currently sits with a 60 under then front vs the 44hd
adam wildman
75 K25 383/400
Re: my 75 K20 upgrades
« Reply #1 on: May 10, 2010, 12:46:50 am »
with that flip kit, i guess the axle has to move forward that much
Offline malibu795
« Reply #2 on: May 10, 2010, 07:00:38 am »
it shoves the rear of the spring down ~8 inches..  if it did it was less than an inch.
adam wildman
75 K25 383/400
« Reply #3 on: May 10, 2010, 09:11:30 am »
Is it just that picture? It looks like its about 4" o.c.
Offline malibu795
« Reply #4 on: May 10, 2010, 11:35:34 am »
very possilbe pic isnt 90* to then truck and  the rear corner of hten fender is rotted off
adam wildman
75 K25 383/400
Offline malibu795
« Reply #5 on: May 23, 2010, 02:32:33 pm »
got my 2wd box and cross over steering installed... went alot easier then expected.
got to do some things to the 52" springs the bushing got installed on the wrong end on one spring so i got to flip the top spring around.
i have new rubber bushing installed 3" up front and 3.5" out back..
then install then srpings
cut then u-bolt down
install shock towers upper and lower mounts.. friend is hooking me up with some 33" long(12-13" stroke) full extention shocks for the front.. i will mount them so i have 4-5" of compression left
measuer for front drive shaft both fully compressed and extended lenghts.. rough gues is i will need something with ~10" of slip travel.
will get pictures up soon  :)
adam wildman
75 K25 383/400
Offline heavychevy91
  • '86 Chevy K20
« Reply #6 on: May 24, 2010, 11:25:53 am »
lookin good man. so whats the difference between the 2wd box and 4wd? and irsh i think it looks like its moved forward because of some of the fender being rusted off
Offline malibu795
« Reply #7 on: May 24, 2010, 03:26:21 pm »
the 4wd is a 3 blind shaft... and only allow the pitnam are to run(stroke) f/r. with a ~2' drag link.. which quickly become out alingment when you start flexing the truck and connects to the DS steering knucle.
the 2wd is a 4 blind shaft and allow the pitnam to stroke l/r  thus allowing one to run a ~4-5' drag link and connect to the PS steering knuckle. allowing one to run upwards of 4x(15" verticle) the wheel travel without binding the steering up with the poor steering geometry from the factory..
adam wildman
75 K25 383/400
  • '86 Chevy K20
« Reply #8 on: May 24, 2010, 05:15:13 pm »
ohhh okay i think i understand what your saying...so is the only real modification to make the 2wd box work is a longer drag link?
Offline malibu795
« Reply #9 on: May 24, 2010, 10:19:51 pm »
yes since the 2wd in normal fasion the pitnam arm swings l/r to operate you normal 2wd IFS steering linkage.  i got the corss over kit form ORD. the drag link runs from slightly left of the left frame rail to the top of the PS knukle.. ~4.5'.. im sure you can imagin how flat that arc will be at the knuckle side of the drag link vs the ~2' DL in the oem 4x4 setup.
currently uploading pictures  ;D
adam wildman
75 K25 383/400
Offline malibu795
« Reply #10 on: May 24, 2010, 11:01:37 pm »
ord cross over with stock lift. and 2wd box
4+1 1/2t 52" rear spring install and sittin at ride hieght
stock lenght shock not quite long enough.. stock is ~18" long i went and bout a par of rear that are ~24" mounted them in the stock loaction... will be re-doing both top and bottom mounts.
pas side shot of steering linkage
front axle sits ~1/2" back.. due to the way i mounted the front hangers... i have another hole i move it forwars and probly will
~2.5' mound dotn have the fornt drive shaft installed/made yet.
max flex no binding  ;D
at full flex/compression
begining hieght
current height
ride quality is 10x better!!!!!!!!!! the 2-3" deep pot hole in my brothers drive are barely noticeable.. and feels much like a IFS
still on the list of thing is
measurements for front driveshaft
re-do front shock mounts
steering dampner.
panhard bar
better engine cross member
sway bar re-instal/modification... lots of body roll ride now.
replace last 12" of rear frame horns install 63" 2500HD rear springs
get an alignment
adam wildman
75 K25 383/400
« Reply #11 on: May 24, 2010, 11:17:35 pm »
Sweet!
Offline Lucky73
« Reply #12 on: May 27, 2010, 11:59:02 am »
Do the frames on these trucks really flex that much,or is it just your truck?(looking at bed to cab movement in pix)
73 Chevy C10
73 GMC K20
93 Chevy S-10
« Reply #13 on: May 27, 2010, 12:40:45 pm »
Yes they flex bad.
Offline malibu795
« Reply #14 on: May 27, 2010, 03:31:04 pm »
the driver side fron cab mount is shot... the floor support is rusted in half..
compare the front bumper angle to the rear bumper angle... that will give you a really good idea..
the bed hasnt really twisted since i put a GN plate in the bed
next onthe list if engine x-member and track/panhard bar... @45mph you hit a bump right you get some good DW not tomention when the locker in the back locks or unlocks.... over/under steer is greatly pronouced
adam wildman
75 K25 383/400
