Author Topic: Headers and starters  (Read 8021 times)
Offline BULLDOG
« on: May 15, 2010, 07:47:08 pm »
I think my starter went out today I have a stock GM style starter and with the headers it is a tight fit and the wires are very close.
Will a mini starter give me some more room.
Black 1983 K20 and sm 465
Re: Headers and starters
« Reply #1 on: May 15, 2010, 08:07:41 pm »
yes
Offline BULLDOG
« Reply #2 on: May 16, 2010, 07:31:43 am »
So,who makes a good mini starter?
What do you all think about the Jegs and summit brands
Offline joesgarage71
  • Wrench
« Reply #3 on: May 17, 2010, 12:13:15 am »
 summit has the one I used on my big block CVS I think. summit branded stuff is good too.
Offline malibu795
« Reply #4 on: May 17, 2010, 12:40:26 pm »
i have ran both summit and jegs... same thing different badging..
goign from a OEM thst sucks ~200-300A and weighte ~45lb  to a mini starger then take 80A and weighs 15 is nice..
i lost one out os 3 i had... it was on a truck one of the wire boots came out and water got in there over then winter and fried it... granted it been on there for 7 years.
adam wildman
75 K25 383/400
Offline 82gmc3/4ton
« Reply #5 on: May 21, 2010, 03:06:07 pm »
I would also suggest getting a heat shield. Aluminum or stainless to keep the heat away from the starter
« Reply #6 on: May 21, 2010, 04:34:10 pm »
There is also a fabric heatshield that wraps around the starter. It has velcro to hold it in place, it works but I used a large hose clamp to keep it in place, worked great.
Offline BULLDOG
« Reply #7 on: May 21, 2010, 07:00:10 pm »
I thought about using some header rap around the header under the starter
Offline fitz
« Reply #8 on: May 21, 2010, 08:45:54 pm »
 I've had good luck with the Tilton mini starter in my Camaro. It definitely increases the header clearance.
  • Wrench
« Reply #9 on: May 21, 2010, 09:10:43 pm »
don't use header wrap. it retains mosture and what you put it on RUSTS!
