Author Topic: Electric fan questions  (Read 26991 times)
« on: May 16, 2010, 08:45:27 pm »
I put in a aluminum radiator today, sweet.  ;D It was almost an inch shorter than the stock one, no big deal, got it to work. This is where I got it, it was a little cheaper when I bought it. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120479345979&viewitem=
The whole setup came with two electric fans, which I haven't put them on yet. I was looking at the fan connectors, and it didn't come with the female ends. Does anyone know of a site that might have something that works? Local parts stores were no help, and I emailed the seller and he said they don't come with them. I would rather find matching connectors instead of buying a complete set and rewiring them.
Lastly, I want to wire them up, obviously, to a thermostat switch. Can I put the thermostat where the yellow arrow is? Any suggestions on a kit? What temperature settings should I be looking for, as in when it comes on, when it shuts off? With the old radiator, I ran the flex fan without a shroud, and as you can see in a earlier pic, it is far from the radiator. Ive never had any cooling problems with it being so far away. Would this kit be good? On 200, off 185 http://www.summitracing.com/parts/SUM-890016/?rtype=10
Offline Layne
Re: Electric fan questions
« Reply #1 on: May 16, 2010, 09:15:05 pm »
I put some female crimp connectors on the spades on mine. I think where either of your arrows will be fine.
« Reply #2 on: May 17, 2010, 01:41:24 pm »
I would rather have connectors.
« Reply #3 on: May 17, 2010, 04:30:38 pm »
I can't see your pics but is this the pigtail you are looking for?
http://www.hrpworld.com/googlebase.cfm?key=Northern%20Wiring%20%20Controls%20-%20Single%20Fan%20Pigtail%20Connector&form_prod_id=,780,835,_6029&action=product
Just get an adjustable thermostatic relay control. You can set the temp at which you want the fan to come on.
« Reply #4 on: May 17, 2010, 05:54:37 pm »
That plug is close. The fan wiring has the male ends, and the two ends are not separated by the plastic divider, as in the picture. Basically, I need the other end. I guess it wouldnt matter if the female end has a divider between the two terminals. Ill browse that site and see if I can find it.
If I were to get the adjustable thermostat, what would be the recommend settings?
Offline bgctrading
« Reply #5 on: May 17, 2010, 06:34:32 pm »
Thats weird I wired up an electric fan a few months ago my fan came with all connections I ordered it from summit. I havent fired it up yet so I couldnt recommend temp settings. But I would think I would want mine to kick on a bit after 200 and off at 195 or so. You can probably never get it below 195 once she is warm.
Offline inovermyhead
« Reply #6 on: May 20, 2010, 02:11:19 pm »
I believe Radio Shack (or "The Shack") has what you are looking for.
« Reply #7 on: January 23, 2011, 04:29:44 pm »
(nevermind)
« Last Edit: January 23, 2011, 08:37:04 pm by beastie_3 »
« Reply #8 on: January 25, 2011, 10:04:02 pm »
« Reply #9 on: January 25, 2011, 11:31:49 pm »
My temp sensor for the fan relay is 3/8" npt but the hole in the intake is larger. I wanted to know where to get an adapter, but I found one at the hardware store.
Offline jthomas12287
« Reply #10 on: January 26, 2011, 01:14:22 am »
if you still haven't found your connector i would take the fan up to radio shack and tell them you need the other end they should be able to get that style molex connector
Offline Psycho71
« Reply #11 on: January 26, 2011, 05:46:52 am »
Or, if you can't find the other side of that particular connector, just cut it off and attach a whole new molex connector. Just a thought, vs going crazy trying to find half of a particular part.
« Reply #12 on: January 26, 2011, 11:29:59 am »
Thats what Im going to do. I saw some GM alternator wire extensions which are pretty thick. Going to cut them up and wire them in and then loom it all. I just installed my thermostat relay kit the other day. Im waiting for a electric fan bracket kit to arrive and we'll see if that works.
Offline 1979C20
  • Kyle Taulton.
« Reply #13 on: January 26, 2011, 03:34:04 pm »
This is the female end of the plug, if you read the description. I believe it has the same terminals as our headlight plugs.
« Reply #14 on: January 26, 2011, 05:22:02 pm »
I already have the other wires. Even though the description says female, the pic shows male terminals. No biggie...
