Author Topic: how do i bypass the fuel selector valve  (Read 49212 times)
Offline 87454westernhauler
« on: May 19, 2010, 03:04:13 pm »
i have an 87 c10 350 tbi truck. it only as the left tank. some one decided to flip the selector switch and now it wont switch back to the left one, and i don't want to spend the 100 bucks to replace the valve. i can see how to by pass the fuel lines but am rilly unshure how to wire it right now because i still am not geting power to the left tamk. help
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Re: how do i bypass the fuel selector valve
« Reply #2 on: May 20, 2010, 08:50:59 am »
that is interesting because it says c10 on the fenders and dash, did not know that it was an r10. when i am messing with the switch in the dash i flipped it to the right hand tank and the gage will work, but when i switch it to the left hand tank the gage goes to the strait right position on the full side but i still do not hear the fuel pump running. i only have the left hand tank on it right now. not sure on exactly what is wrong with it, but it may be the valve so i will look into getting a new valve unless you guys think it is some thing else. i am up to suggestions. thanks in advance sam.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #3 on: May 20, 2010, 09:25:46 am »
simplest thing would be to physically connect the lines from the left tank to the lines after the valve, and leave the selector switch on the dash set to the left tank.   If it still wont run, you'll have to get to the wiring under the dash behind the switch and connect them up manually.
« Reply #4 on: May 20, 2010, 09:35:33 am »
how do i connect them manuely behind the dash?
  • Z62 ON-ROAD
« Reply #5 on: May 20, 2010, 10:00:57 am »
You'd need a wiring diagram, i dont know which is which, but the switch itself controls the valve, as well as a line for each fuel pump, and each sending unit.   What you have to hard wire, are the leads for the fuel pump power, and the leads for the fuel gauge.  you wont have to worry about the leads for the valve.
Here's a link
http://forum.73-87chevytrucks.com/smforum/index.php?topic=9072.0
Though it may be a bad switch too.  they used a foam dust seal on the switches and after a time the foam disentegrates and gets down on the contacts.  maybe a good cleaning would fix you up and you wouldnt have to do anything else.  I've had to do this on every dual tank truck i ever had.
here's a thread on refurbishing your switch.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6537.0
« Last Edit: May 20, 2010, 10:04:03 am by 78 Chevyrado »
« Reply #6 on: May 20, 2010, 08:48:00 pm »
The switch is different for carbureted vs tbi. If you look in my mutt project thread you will see where I just set one up. The selector valve there are two different options. If you want to bypass it then it's easy enough and we've had quite a few threads on this if you use the search function
« Reply #7 on: May 24, 2010, 02:20:06 pm »
i got it to run friday, i just kept switching the valve until it went to the left tank and it fired right up. i think that the switch in the dash is faulty. used it all day saturday to pull a manure spreader around in a field 8) and it seemed to work ok but it runs rough still.  :-\
would anyone have the diagram for the firing order on an 87 350 TBI v8 chevy R10 manuel 4 speed by chance??? ???
« Reply #8 on: May 24, 2010, 04:34:29 pm »
18436572 clockwise
« Reply #9 on: May 25, 2010, 11:46:53 am »
do you have the charts/ picture of it.
« Reply #10 on: May 25, 2010, 04:51:34 pm »
« Reply #11 on: June 01, 2010, 09:41:53 am »
ill try that tonight. it is spazing again wont fire on all cylinders. cant get it to run good enough to idle or run on its own. i am going to try and get a new cap and rotor an the distributor this week sometime this week if i make it to the parts store. ill try checking my firing order too. thanks guys.  :)
