General Discussion
1994 r-134a ?
Topic: 1994 r-134a ? (Read 17115 times)
Re: 1994 r-134a ?
Reply #15 on:
May 25, 2010, 11:57:29 pm »
small little detail lol.
Re: 1994 r-134a ?
Reply #16 on:
June 05, 2010, 01:56:09 am »
my dad being hard headed don't seam to think you "need" to vacuum the system he being an old school guy that never went to school to be a mechanic just been doing it as a job for since i was a kid and but anyway think I'll sneak over to the shop and do it behind his back lol. what would cause the system to read full (low side in green about 40) only after adding once can of freon? you can head freon moving in the condenser but the low hose isn't cool anymore the high side is hot tho
Re: 1994 r-134a ?
Reply #17 on:
June 05, 2010, 05:52:47 am »
I'm not following what you are saying
Yes you do need to vacuum the system. Tell your dad since he's old school the old saying "do it right the first time" comes into play here.
http://www.aircondition.com/tech/questions/38/
Re: 1994 r-134a ?
Reply #18 on:
June 05, 2010, 06:16:41 am »
that was going to be my next question about the venturi pumps. i guess autozone used to rent out pumps but now they don't so if i cant get a hold of the guys at the shop i guess ill go to harbor and pick one of those up
Re: 1994 r-134a ?
Reply #19 on:
June 05, 2010, 10:58:48 am »
They're better than nothing but if the system has been open you really want to use a vacuum pump. You know any HVAC guys?
Re: 1994 r-134a ?
Reply #20 on:
June 05, 2010, 03:52:33 pm »
One guy that hunts on the farm deals with that stuff ill try him thanks vile. I guess I never thought of home and car being about the same ideal
Re: 1994 r-134a ?
Reply #21 on:
August 06, 2010, 11:49:55 pm »
OK vile its been a while but finally got the system working. After just dealing with the heat thought I suck up a little to the wife and fix the AC well took it to my uncle's shop and talked to him about my problem we start looking over it and my problem was the compressor would kick on and off very rapidly. So he hooked his gauge set up and saw my high side was way to high he said shouldest like a blockage. We looked over the system and told him everything is new except the evaporator. We talked about how the system works I learned allot the we talked about the orifice tube and how it works then I showed him were it was at and that it was facing the right way but then he questioned were it was at on the condenser. It was In The right spot but I had the hoses switched and had the discharge on the orifice tube and on the bottom. So took of home and did it right everything works nice and cool yet its only sitting at 30lbs but with the outside temp it should be about 50 so I might need to pick up a small bottle of freon. Thanks for your help on this vile
Re: 1994 r-134a ?
Reply #22 on:
September 17, 2010, 05:24:08 pm »
Vile I've searched online can't seam to find it but what's the sensor that screws into the accumulator part # that I'm reading is gm52436358
Re: 1994 r-134a ?
Reply #23 on:
September 21, 2010, 09:39:46 pm »
In the accumulator it would be the low pressure switch.
General Discussion
1994 r-134a ?
