Author Topic: 2500 HD wheels on my 86 rub  (Read 10348 times)
Offline 1toncrew
« on: May 29, 2010, 06:02:31 pm »
I have installed the 2500 HD wheels and tires on my 1986 1 ton crew cab 4x4. Tires are 265/75/17. The problem is that the left tire rubs on the steering link when I turn all the way to the right. Has anyone else had this problem and if so what can I do to fix it?
Thanks
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: 2500 HD wheels on my 86 rub
« Reply #1 on: May 29, 2010, 08:34:13 pm »
Can We get a pic of your truck with those wheels on it?  I have the 16 inch rims, but have been wondering how the 17's would look.
If the offset on your 17's is similar to the offset on my 16's, a set of 2" wheel spacers would fix you right up.  If I keep my 2500HD wheels, I'm getting spacers for them.
« Reply #2 on: May 29, 2010, 11:32:55 pm »
Thanks
stop making left turns. ups has done this and they have saved allot of money ;D but like78 said wheel spacers should do the trick
« Reply #3 on: May 29, 2010, 11:56:19 pm »
Make sure your steering isnt off. Turn the wheels each way and see if they turn farther to one side than the other.
« Reply #4 on: May 30, 2010, 12:02:00 am »
with your tires off cause the one will bind you all ready know that
Offline 1toncrew
« Reply #5 on: May 30, 2010, 08:14:02 pm »
Here is a picture of the truck. It may look rough, but it does everything I ask it to. 4 speed 410 gears and 454 engine. I will go and check the offset and check the steering. I have no experience with spacers. I guess a wider stance is a good thing. I bought the used rims and tires because I am cheap, and it was cheaper than buying new tires. Plus I think it is an upgrade. I don't want to spend more money, but if I have to buy spacers then I want the good ones. What brand should I be looking at. Does anyone have a good source?
Thanks again
« Last Edit: May 30, 2010, 08:15:59 pm by 1toncrew »
Offline Da67goatman
  • Burban
« Reply #6 on: May 31, 2010, 12:20:40 am »
Depending on how wide you want to go, ebay has a large variety of aluminum spacers, but for more than an in each side i'd look into steel ones for strength.
<Pitcrew>
Offline three8six
« Reply #7 on: May 31, 2010, 10:33:45 am »
I think a solid peice of cnc cut aluminum would be plenty strong. I have not steel spacers. I would think a 2 inch chunk of steel on each wheel would have to add alot of unsuspended weight right?
  • Z62 ON-ROAD
Offline 1toncrew
« Reply #9 on: June 02, 2010, 06:47:15 pm »
Thanks Chevrado. I have measured the back spacing on the wheels. The new HD wheels are 7/8 inch more backspace. Plus wider tires and I am about 1 1/4 more on the inside of the truck. I am looking at buying 1 1/2 inch spacers. The original lugs are 1 1/4 - 1 1/2 long and I don't want to cut them if I can help it. So I will go with the 1 1/2 inch spacers. Should I do all four wheels or just the front? I am thinking all four
Offline malibu795
« Reply #10 on: June 06, 2010, 08:45:02 pm »
got a pic of said rub area?
i have put 16" wheel on a D60and D44HD with 5.125" BS and not rubbed
adam wildman
75 K25 383/400
