Author Topic: Is my 305 getting tired? :(  (Read 4124 times)
Offline The Lady In Red
« on: June 02, 2010, 02:09:55 pm »
Hi guys...
Ok, My 86 Chevy K10 has an issue that seems... well... unrepairable by making adjustments.  For starters, I want to make it clear that the original Q-jet was replaced by an edelbrock performer of some type.  It looks like a 650. Also, the EGR valve has been removed and blocked off in order to make room for the bigger carb.  I did not make these changes, its the way it came to me.
The timing set needed replacing when I got it.  It still ran, but adjusting the timing was useless, and I had loads of preignition.  After the new gear set was installed, I made some carb adjustments and set the timing at 6 deg before TDC.  Here is the problem:
When I am running it as it is adjusted by the book, I still get some pinging, more so under heavier load. When I hear it, I can either give it more gas, or let off, and it stops.  If I tweak the distributor back a bit (clockwise) the pinging will stop, but it takes away from the trucks power and it bugs me that it strains the engine.
I have been told that better gas, or advancing the valve timing may help the problem temporarily.  However it is a terminal issue, and that the engine will need to be rebuilt/replaced soon.  Someone please tell me that this can be caused by something I may be missing... I don't feel like installing the new 350 until I have everything I need to complete the front end and tranny at the same time.   :-\
Offline Grim 82
Re: Is my 305 getting tired? :(
« Reply #1 on: June 02, 2010, 03:40:22 pm »
Does it have ESC? It could be a faulty knock sensor.
« Reply #2 on: June 02, 2010, 04:13:27 pm »
Hmmmm... I never thought of that...???  There was so dang many things disconnected on this truck when I got it that I would not be surprised if someone fiddled with it.  I'll have a look and check back.  Thanks Grim.
« Reply #3 on: June 02, 2010, 04:35:02 pm »
Use a standard HEI, Hopefully you put your timing set in correctly. EGR would help reduce your pinging drastically. Make sure it's not running lean and run the correct spark plugs. What plugs are in there now? You should be running the equivalent of an R43CTS. Anything hotter will cause pinging. Finally a decarbonizing may be in order. Top Engine Cleaner works better than sea foam if you can get your hands on some. Make sure you change your oil after you use it though. Good Luck
