Author Topic: misfiring  (Read 5995 times)
Offline 86charcoalsierra
misfiring
« on: June 04, 2010, 06:16:15 pm »
I got a 86 gmc sierra with the stock 305 it recently started to miss fire when i step on the gas it has only been about 2 months since i changed the spark plugs i changed the spark plug wires and the distributer cap but it still misfires what else should i check.
Re: misfiring
« Reply #1 on: June 04, 2010, 07:31:18 pm »
Misfire, do you mean a popping sound?  Could mean a lobe down on the cam.  One of the spark plugs could be bad as well unless when you changed them the problem didn't go away... My $.02
Re: misfiring
« Reply #2 on: June 04, 2010, 10:46:39 pm »
make sure a plug wire doesn't have a bad connection, could of had a good one but just popped off
Re: misfiring
« Reply #3 on: June 05, 2010, 06:09:22 am »
Go through and double check everything in the ignition system. Plugs, gap, wires, cap, rotor, firing order, timing. Is it backfiring or misfiring?
Re: misfiring
« Reply #4 on: June 05, 2010, 06:19:01 am »
if it is a backfire wheres it coming from carb or tail pipe?
Re: misfiring
« Reply #5 on: June 05, 2010, 01:32:18 pm »
It sounds like it is backfiring from the tail pipe.
Offline 1980c10
Re: misfiring
« Reply #6 on: June 05, 2010, 01:46:43 pm »
check the wires (inside of your distributor) leading up to your vacuum advance.
Re: misfiring
« Reply #7 on: June 05, 2010, 03:49:18 pm »
Check all you wires. Is it only when you get on it?
Re: misfiring
« Reply #8 on: June 05, 2010, 06:27:39 pm »
It does it when i get past about 20 mph if im just cruising slow it runs good but when i push the gas it starts to misfire.
Re: misfiring
« Reply #9 on: June 05, 2010, 07:22:43 pm »
Did you change the rotor
Offline 1980c10
Re: misfiring
« Reply #10 on: June 06, 2010, 07:07:26 pm »
sounds like it is misfiring when the vacuum is pulling on the vacuum advance causing the wires inside of your distributor connecting to your vac.-adv. to seperate. this is a very common wear point. take off your dist cap and rotor and you will see what to check.
