Author Topic: removing 4x4 rotors  (Read 11844 times)
Offline Plunkett
removing 4x4 rotors
« on: June 05, 2010, 12:08:05 pm »
I bought a 86 chevy silverado 4x4 this past week. This is my first 4x4 truck, so I'm new to some things on it. I need to take the rotors off and have them turned. I never have messed with taking rotors off a 4x4 truck before, so I'm needing some help on getting them off. Is there a link that someone could post, so i can see how to remove them? Thanks in advance.
Offline bgctrading
Re: removing 4x4 rotors
« Reply #1 on: June 05, 2010, 12:47:09 pm »
It is easy to take the rotors off just takes a little time. But may I recommend getting them turned with an on car brake lathe for a truer job???
« Reply #2 on: June 05, 2010, 12:50:57 pm »
Remove wheel, remove calipers, remove hub, remove bearing nut, remove bearings and then slide it all off the spindle. The inner bearings are held in with a seal, so you dont need to worry about them falling out, but the outter bearings will fall out.
« Reply #3 on: June 05, 2010, 04:06:12 pm »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=14931.0
Also check on your axle ujoint maybe time to replace them while you have the hub off
« Reply #4 on: June 05, 2010, 04:07:44 pm »
X10!
« Reply #5 on: June 05, 2010, 04:08:53 pm »
I adjust the wheel bearings and use the on car lathe. If you have a local shop that has an on car lathe that's your best bet. If you want to take them off you'll need the spanner nut socket to remove the lock nut and wheel bearings.
« Reply #6 on: June 05, 2010, 04:10:15 pm »
The spanner nut socket is a good investment. I got one for about 12 bucks at o'rileys.
« Reply #7 on: June 05, 2010, 07:27:09 pm »
Ii dont know. Don't know how many times I did it with a punch or chisel till I Finally got the socket put it this what probably won't be the last time you take it off I would get the socket
« Reply #8 on: June 05, 2010, 08:04:33 pm »
I agree. It didnt take me long to give up and get the socket. Even then, I had to crank on the ratchet to get it off.
