Author Topic: Transmission temp gauge  (Read 5396 times)
« on: June 05, 2010, 04:16:36 pm »
Should the sending unit be in the hot or cold line of the transmission? I assume the hot line...
Re: Transmission temp gauge
« Reply #1 on: June 05, 2010, 04:19:49 pm »
Hot
« Reply #2 on: June 06, 2010, 06:49:05 pm »
OK, thats what I thought, although B&M say to use the cold line. But it makes sense to use the hot.
The gauge came with a sender that goes into the transmission, not a inline sender that I thought it would. Is there somewhere on the TH-350 to place it or should I get the kit for the line?
Offline malibu795
« Reply #3 on: June 06, 2010, 08:40:29 pm »
hot line.. iirc its the top line coming out of the tranny..
it would be most refelant to fluid temp coming out of the TC were 80-90% of the heat is generated
adam wildman
75 K25 383/400
Offline Armor
« Reply #4 on: June 10, 2010, 04:26:56 pm »
definatly the hot,
id rather know what the temp is not what its being cooled to, i have a great aftermarket cooler in the mix on mine and it cools it down very well, (had a second gauge installed at the start so i could compare but my uncle wantd it back), keeping an eye on the temp will save these things
« Reply #5 on: June 10, 2010, 08:41:03 pm »
http://www.bmracing.com/bmracing/installation_instruction/9500048-08.pdf
I just think it is funny B&M says the cold line.
Offline ccz145a
« Reply #6 on: June 11, 2010, 11:14:57 am »
I think B&M wants you to see how "good" thier cooler is in dropping temps rather than the more useful actual temp of the fluid before cooling that would be more reflective of the temp inside the transmission.
