Author Topic: need help with tuning  (Read 5022 times)
Offline jamiebarnesjr3
« on: June 06, 2010, 04:49:36 pm »
well what i have is a 1985 chevy 350 bored over 30 compleate rebuild all new. heads are mild street heads 194's, roller rockers aluminum 1.5, deck was milled 10 under not sure of compression im running a brand new holly 4 barrel 600 cfm single feed, edelbrock performer rpm cam and intake. my problems i cant get the thing to sit still so i need some info.
1 what should the vac be at idle hooked to the rear of the carb at 900 rpms in park
2 wgats the best way to adjust these holly carbs my father messed with the air/fuel screws so i need a base point like the factory settings like 20 screws out 3 screws out or whatever
3 how do i set the timing with a vac guage lights useless cus we put the wrong pointer on it
basiclly what im tryin to do is get this thing to where it just sits in the bay an purs without shaking and the idle fluctuating between 900 an 1200.
also any ideas of the hp or torque this thing should put out i like hearing other ppl ideas.
so basiclly i just need a complete guide to tune thius thing in perfect without a timing light in laymans terms please help ive been workin on this thing for 3 years ive tryed tuning for 3 weeks and im ready to give
Re: need help with tuning
« Reply #1 on: June 07, 2010, 12:15:26 am »
1) Not sure how much, but you want to adjust to get the highest vacuum rating, regardless of what it is.
2) start at 2 turns out.
3) set the timing with a timing light at 10 degrees, if you don't have one get one.  If you insist on doing it by ear, set it at the highest reading also.
You should not be idleing at 900rpms.  It should be about 750 with and auto.
Offline Josh454
« Reply #2 on: June 07, 2010, 08:17:01 pm »
I would guess you probably going to be around 12 to 14 inches of vacuum.  No matter what you do it's not going to, "purr" that's a lot of cam with not much compression.
Sounds like you may have something else going on though.  Checked for vacuum leaks?
« Reply #3 on: June 09, 2010, 01:04:52 pm »
ok sorry it took so long been busy with work, ive tightened intake down no vac leaks,im re adjusting the valves now all i need to know is what causes the carb to leak white smoke after i turn the engine off
Offline Grim 82
« Reply #4 on: June 09, 2010, 03:30:18 pm »
Unburned fuel / flooding. It could be improper float adjustment or excessive fuel pressure.
