Author Topic: 4 cly not getting complete combustion  (Read 3864 times)
Offline markdilljr
  • Me on Hopper "Covered"
« on: June 11, 2010, 12:12:50 am »
I have a 84 C10 with a 350, problem I am having is I cant pass smog due to blowing over 3 times the limit on CO. I pulled off plug wire one at a time and have 4 of them that have no change in motor when pulled off # 3,5,2,8. They are getting spark to the plug, I have replaced cap, rotor, plugs, plug wires, air filter, pcv valve, all vacuum lines, rebuilt carb, set timing, intake manifold gasket ( there was a small leak ) changed oil, changed coolant and put two new cats went for a re-test and no diff. Still no change when I pull the wires on the 4 cly. I am out of money and ideas, please help
Ride Rank, Make Bank
Re: 4 cly not getting complete combustion
« Reply #1 on: June 11, 2010, 05:23:03 am »
Do a compression test
