Author Topic: Couple questions about the 10 bolt??  (Read 5112 times)
Offline jefferias
« on: June 12, 2010, 03:57:49 pm »
hi everyone!  i have an 84 c10 350/350 and a 10 bolt rear with 3.08's.  i noticed my pinion seal was starting to leak, so i bought a new seal and researched a lil bit.  I put the seal in last night. this was how i did it.  1 disconnect driveshaft
            2  mark the flange for u-joint and 2 punch marks on nut and pinion shaft. counted threads  showing as well
           3 raise vehicle and measured about 12inch pounds on the pinion nut
           4 remove nut and remove companion flange
           5 remove seal, clean all necessary things
           6 install seal,lube lips with grease
           7 install companion flange with sealant on splines
           8 install washer and pinion nut(lots of blue loctite) with impact gradually till i measured 13 inch pounds.
          9 reinstall driveshaft
--so all is well so far, no leaks or noises but only put on like 10 miles.   my question is-- i tried to pull the front pinion bearing just to inspect it and couldnt get it off all trhe way so i just put everything back togetther. my bro thinks it shouldnt be floating the way it was-as i could move it back and forth maybe 3/4 inch. i said its fine and got pressed back on the pinion shaft with torqueing the pinion nut.  so should the bearing be loose like that or pressed on. like i said so far the fix seems to be absolutley fine. hope you guys can solve this for me and thanks in adavnce.  sorry so long of a post!!
Re: Couple questions about the 10 bolt??
« Reply #1 on: June 12, 2010, 07:21:26 pm »
Quote
How'd that taste?
The pinion bearing gets preloaded by tightening the pinion nut with the companion flange installed
« Reply #2 on: June 12, 2010, 09:29:04 pm »
You used an impact to get 13 in lb?
Offline jefferias
« Reply #3 on: June 12, 2010, 11:36:14 pm »
it was luibriplate-yum yum     and yes impact was needed- as that pinion nut has 3 spots that "lock" on the pinion shaft thats why its so tight- but the rolling resistance was a different story(13"lbs).  thankz vile, i figured i was fine--i will keep posted if anything happens.
« Reply #4 on: June 13, 2010, 04:24:24 am »
Just make sure your witness marks are lined up
Offline jefferias
« Reply #5 on: June 13, 2010, 11:04:32 am »
when i got to the witness marks it was a bit shy of my torque measurement so i went a tad extra to make up for the drag on the new seal.  thankz man!!
« Reply #6 on: June 13, 2010, 11:35:24 am »
You shouldn't have any issues then. Good luck
