Author Topic: ss front end  (Read 4955 times)
Offline bigal04
ss front end
« on: June 17, 2010, 09:40:00 am »
Hi im new to the forum. I wanted to know if a ss front end off a 90 model will fit on a 78 model. Front end i mean fenders and grill
Re: ss front end
« Reply #1 on: June 17, 2010, 11:29:50 am »
If the 90 is the newer 88-98 body style, no. If the 90 is from a 81-91 square body style, yes BUT you need the whole front clip. There is a post in the tech section on what you need. I dont think they made the SS in the older body.
Offline 80stepsideguy
Re: ss front end
« Reply #2 on: June 17, 2010, 12:25:47 pm »
Think he is referring to the SS 454 front end.The answer is no it will not work, the 2 are completly different as far as trucks, body lines, bolt hole locations.Besides why would you want to screw up the great lines of a 73-87 chevy truck in the 1st place????
thanks
pat
1998 Chevy 1500 S/B 2wd
Re: ss front end
« Reply #3 on: June 17, 2010, 12:45:01 pm »
No it will not work.  You can put a 89-91 R/V front end that looks the same/simular.  Several posts on this..
Offline bigal04
Re: ss front end
« Reply #4 on: June 17, 2010, 07:46:20 pm »
Thanks. I don't want to mess up the body line but I like the grill
Offline Koots
Re: ss front end
« Reply #5 on: June 17, 2010, 10:21:31 pm »
The 89-91 SUV (Burb/K5) front ends were redesigned to update the older body style to resemble the 88+ GMT-400 body style which is what you are looking for. The 454SS has nothing special over any other composite headlight grille from 88-94 other than a color matched shell and air dam w/fog lights, which is easily recreated.
