Author Topic: MSD 6A  (Read 4793 times)
Offline markdilljr
  • Me on Hopper "Covered"
MSD 6A
« on: June 17, 2010, 03:43:45 pm »
I have a 84 C10 350 w/TH350, I put on MSD cap and rotor I still have to get the MSD wires. My roommate gave me a MSD 6A ing. box, I heard I need some special wire to make it work on with my HEI dist. My question is will the box make a difference in HP and MPG, is it worth the time to install it or should I not even mess with it and what ( wires ) do I need to make it work with HEI
Ride Rank, Make Bank
Re: MSD 6A
« Reply #1 on: June 17, 2010, 10:23:14 pm »
You need the harness that plugs into the distributor and into the msd module. If you don't have that then just keep the box as a spare for when you do upgrade ignition systems
Offline malibu795
Re: MSD 6A
« Reply #2 on: June 17, 2010, 10:45:51 pm »
IMO def worth the time
and x2 what vile said
adam wildman
75 K25 383/400
Offline markdilljr
Re: MSD 6A
« Reply #3 on: June 19, 2010, 09:36:36 pm »
Thank you will hold onto it until I get the harness
Offline frotosride
    • WFO CONCEPTS
Re: MSD 6A
« Reply #4 on: July 23, 2010, 09:11:03 pm »
It's def worth the time..the typical hei falls off just over 4500rpm and typically has loss of power..but the factory did it the cheapest was possible. The msd will ensure a strong spark just shy of 7000.. not that you are reeving that high but if u need it it's there. :)
