73-87 Chevy & GMC Trucks
1980 P-30 Ignition wires?
Topic: 1980 P-30 Ignition wires? (Read 13604 times)
Novadiecast
June 25, 2010, 08:09:36 pm »
Can someone point me in the right direction here. I have a 1980 P-30 Chevrolet Box truck and the previous owner cut the ignition wires at the key switch and installed some aftermarket type of key switch. I have a new key switch for the truck and the correct plug that plugs into it. The problem is the colors of the wires do not match up correctly. I need a wiring diagram for this P-30 Step Van so I can hook it up correctly. Anybody know where I can turn?
?? Thanks in advance for your help.
Last Edit: June 25, 2010, 08:42:47 pm by Novadiecast
1985 Crew Cab dually project soon to be SRW Short Bed
Re: 1980 P-30 Ignition wires?
June 25, 2010, 09:17:46 pm »
I would suggest you get a service manual.
⌠ŻŻŻŻŻ' [☼===☼]
beastie_3
Josh
June 26, 2010, 01:06:47 am »
I agree with a manual. How many wires are there, and what is each color? Include the color of the stripe, if there is one. Also, look at your starter and see what color wires are going there as well.
Semper Fi
Novadiecast
June 26, 2010, 10:12:54 am »
I too would like a manual, just don't know where to find one.
The problem is the wires in the harness do not match up to the plug that was left in the truck(assuming it was the original that was cut off). I got one from an earlier step van and those colors are different also. So a diagram would show the pin out of the plug, I hope.
beastie_3
Josh
June 26, 2010, 10:54:10 am »
Looks like there is a manual. I just did the hard work for you. Search.
http://www.gregsonline.com/eshop/CDs/Chevrolet/80TSMC.htm
Semper Fi
Novadiecast
June 26, 2010, 11:02:45 am »
Thank You!!!! I have searched and searched for 5 days now!!
jaredts
June 26, 2010, 11:36:41 am »
How many wires are there? A service manual would be nice, but with a multimeter I would think you could figure it out. There should be a wire hot all the time, a wire that gets 12v in the acc, on, and start positions. Using the existing switch as a guide with a meter, you should be able to track down which wire goes where. If I was into my column I'd take a picture for you to show the colors.
Novadiecast
June 26, 2010, 12:12:49 pm »
There are 7 wires and it is not in the column it is in the dash like a van.
jaredts
June 26, 2010, 03:25:28 pm »
Sorry, should've read a little closer.
Novadiecast
July 02, 2010, 04:12:49 pm »
Ok, got the manual above 35.00 and it says in the index:
Ignition switch operation circuit go to page...................Page 8A-21
Guess what....it stops a 8A-16 then goes to 8B-1, there is no page 8A-21?
Now what???
beastie_3
Josh
July 02, 2010, 06:24:46 pm »
Call them.
Semper Fi
Novadiecast
July 07, 2010, 07:31:19 am »
We you can't call them. You have to send an email. I did that and have got no response from them at all. I sent a second email today......
This thing is driving me crazy!
zieg85
July 07, 2010, 09:44:56 am »
I have a set of Mitchell manuals on CD Rom, I will look to see if they list what you are looking for...
Novadiecast
July 07, 2010, 02:30:49 pm »
Thanks Zieg!!
zieg85
July 07, 2010, 03:22:41 pm »
My manuals on CD-rom only go back as far as 1983, sorry. My old desktop was not being very nice and froze up... It is only 105 degrees in the garage, can't imagine why it did that...
