Interior & Equipment
Heating, Ventilation & Air Conditioning (HVAC)
BBC A/C brackets for R4 style compressor
Topic: BBC A/C brackets for R4 style compressor (Read 24836 times)
Injected
June 26, 2010, 07:15:02 pm »
I've got an '85 K10 Silverado, I swapped out the 305 with a 454 and would like to hook my A/C back up. I've got the R4 compressor (short style), I need brackets for the BBC.
Did they ever use this compressor on the big blocks? I've been calling and searching junkyards and can't find anything. Anyone know what they would have been installed on from the factory with a big block setup?
or aftermarket - homemade brackets?
Since the A/C setup worked fine before the engine swap I don't want to switch compressor styles to the longer one.
Thanks,
Greg
123 pugsy
Re: BBC A/C brackets for R4 style compressor
June 28, 2010, 05:59:03 pm »
Heres a link for the whole set up.
Is that the syle AC comp you have?
http://paceperformance.com/index.asp?PageAction=VIEWPROD&ProdID=243737
If so there are 2 brackets #10187612 and #10187613.
Pugsy
76 C10 LWB
TPI 350
June 28, 2010, 07:30:25 pm »
Here is the bracketry for the 454. The A6 compressor was used
123 pugsy
June 28, 2010, 07:37:18 pm »
I believe OP wants to use his short compressor on the 454.
Pugsy
76 C10 LWB
TPI 350
June 28, 2010, 07:40:22 pm »
Then he will have to use a late model set up because the V-belt system used the A6. The late model bracketry will work but will be serpentine.
HAULIN IT
June 28, 2010, 08:20:59 pm »
I adapted the 305 A/C brackets onto a 502 when we put it in my friend's '83 Caprice quite a few years ago. Worked out great & really wasn't that hard if you have some basic skills & desire. The owner of the car gets asked quite often about "What year/vehicle did that bracket come from?"
We never discharged the air while doing the swap, the hose that goes across the engine looks a little shorter than it should be but has never been a problem...that's been 10 years ago or so. There are several other parts on it that someday will make someone scratch their head a bit. The transmission crossmember is from a mid 90's Crown Vic (dual humps made for the cats) with the original mount portion cut off of the Caprice & welded to the Crown Vic one. The mount portion has the GM part number...I'd love to be a fly on the wall when someone goes to the dealer & orders the "double hump" crossmember & gets the goofy angled stock one.
Go for it! Lorne
123 pugsy
June 29, 2010, 05:13:55 am »
The compressor in the link I provided is an R4. Its just uses the serpentine belt. I'm pretty sure the same brackets would work.
Only problem is that they charge an arm and two legs for them.
With the prices they charge, I would make my own also.
Pugsy
76 C10 LWB
TPI 350
Injected
June 30, 2010, 02:43:46 pm »
Thanks for the info guys.
I figured a serpentine setup was the factory answer, but I'm not sure I want to switch over right now so I think I'm going to make my own brackets to get it to work.
I was thinking maybe some rods with adjustable spherical style ends, I've seen some street rods hang compressors that way - think it would work?
Greg
123 pugsy
June 30, 2010, 03:22:32 pm »
All I know about making the AC brackets is that they should be quite strong.
Last time I made some up, the brackets were too flimsy and caused me nothing but grief.
Pugsy
76 C10 LWB
TPI 350
June 30, 2010, 03:32:52 pm »
March Performance makes some.
http://www.marchperf.com/cbb_brackets.html
Injected
July 01, 2010, 08:23:04 pm »
I'll check it out, thanks!
HAULIN IT
July 04, 2010, 02:37:49 pm »
Just found this today while on another site...check it out! Lorne
http://www.kwikperf.com/bbc_serp_kit.html
1bad75
New Users
Reply #12 on:
July 27, 2010, 09:43:52 pm »
im trying to find one of the brackets myself i need the one that hangs to the head for an a6 type compressor on my 75 c10 its got a 454 in it any idea of where i can find it
Reply #13 on:
July 28, 2010, 06:47:09 pm »
Junk yard, ebay, classifieds
