Author Topic: New Motor and No Temp  (Read 6413 times)
Offline msc5195
« on: June 29, 2010, 10:48:51 pm »
I just installed a new 383 stroker(installed on saturday). Prior to th(Friday) all of my gauges worked fine. With the new engine I installed a new sending unit and now my temp gauge doesn't work. I pulled the wire off and grounded it to the chassis and the gauge pegged out. I went today and purchased another sending unit and still no working gauge. The sending unit is screwed into the new aluminum head on the drivers side and yes I did install a new radiator with dual electric fans but it doesnt run that cool. Any ideas on what could be the problem?
Re: New Motor and No Temp
« Reply #1 on: June 29, 2010, 11:04:56 pm »
check to see if there is a break in the wire somewhere between the sending unit and the gauge.
« Reply #2 on: June 30, 2010, 12:07:58 am »
you have fluid come out of the port where the sending unit goes? how long did you drive it for?
Offline msc5195
« Reply #3 on: June 30, 2010, 08:03:49 am »
 No break as when i ground the wire the gauge pegs out.
Offline msc5195
« Reply #4 on: June 30, 2010, 08:06:08 am »
Yes when I pulled the sender to replace it I had water come out of the hole. The enging sat in the drive way and idled for 30 minutes and the gauge never got over 100°. I even unplugged the fans and let it idle for about 5 mins with the fans off but the gauge never moved.
« Reply #5 on: June 30, 2010, 08:16:18 am »
Use a ohm gauge and check the unit then boil it and check it again see if it moves
Offline markdilljr
  • Me on Hopper "Covered"
« Reply #6 on: June 30, 2010, 02:48:27 pm »
I had almost the same problem, it ended up being that the parts store keep giving me one for a dummy light so it wouldnt read until about 40-45 min then would peg hot. If you let it sit and run for 45 min what does it do
Ride Rank, Make Bank
Offline msc5195
« Reply #7 on: June 30, 2010, 04:01:10 pm »
Ok I removed the sender and held a lighter to it and after about a minute it pegged out the gauge. I went and bought an aftermarket gauge and the sender for it will work the aftermarket gauge but not with the factory gauge. Now the parts store is telling me that I need the newer style two wire sender as the one I have is for a dummy light. With that said my old(1978) motor that I just removed had a single spade sender and it worked well, if the new sender has two wires is the extra wire a ground? I only have one dark green wire going to the sender.
« Reply #8 on: June 30, 2010, 04:46:24 pm »
All of the coolant temp sending units should be a single wire. The coolant temp sensor if for the ECM and not the gauge.
Offline msc5195
« Reply #9 on: June 30, 2010, 06:10:59 pm »
Thanks. Dealing with these parts store people is something else. According to the Borg Warner website I need a WT5133 and I currently have a WT357.
« Last Edit: June 30, 2010, 06:12:38 pm by msc5195 »
Offline msc5195
« Reply #10 on: June 30, 2010, 06:16:14 pm »
 Not sure about the plug in on the WT5133. Just ordered one thru O'Reilly Auto Parts so I will see tomorrow if it works.
