Author Topic: Rpm too high!!  (Read 4516 times)
Offline fabioblazer
Rpm too high!!
« on: June 30, 2010, 01:18:40 pm »
Hey guys! a question please
thanks!
i rebuilt my engine, all is ok, just a thing is weird.
i started engine for a first test, i removed valve cover, i adjusted valves and it ran good.
but when i reassembled valve covers, i started the engine again but, without touching accelerator pedal, engine speed (RPM) were so high that i had to shut it down!!
i saw that carb throttle linkage stop, doesn't touch fast idle screw as before!
someone has some good idea!?
Thanks for attention guys!
Fabio
Offline Grim 82
Re: Rpm too high!!
« Reply #1 on: June 30, 2010, 02:09:26 pm »
Is the throttle return spring hooked up?
Offline jaredts
Re: Rpm too high!!
« Reply #2 on: June 30, 2010, 02:35:40 pm »
Is this a factory quadrajet (what carburetor)?  When it revved high did you try to tap the throttle to get it to idle down?
Offline fabioblazer
Re: Rpm too high!!
« Reply #3 on: June 30, 2010, 02:55:14 pm »
thanks for answer!
yes rochester quadra-jet. it has just 2 years.
i tried to close linkage manually but it's too hard, just if i turn manually the choke, throttle linkage touches the idle screw on the driver side, but as soon as i push down accelerator pedal, throttle linkage turns back but it is too distant from idle screw, as if i push down accelerator to the floor!
i tried to remove spring and accelerator cable, without nothing, but the problem remains
Re: Rpm too high!!
« Reply #4 on: June 30, 2010, 03:41:19 pm »
So you are on the fast idle cam then. Is the choke rod hooked up and moving freely? If so check the vacuum choke break.
Offline fabioblazer
Re: Rpm too high!!
« Reply #5 on: June 30, 2010, 04:02:48 pm »
all moves freely but throttle linkage doesn't come back completly.
maybe i must turn back choke linkage or precisly fast idle cam, but i didn't touch anything!
just after removing and reassembling valve covers
maybe i touched something but it would be extremly strange
Re: Rpm too high!!
« Reply #6 on: June 30, 2010, 04:40:14 pm »
Did you knock the vacuum hose off of the choke break?
