Author Topic: what size bolts  (Read 5408 times)
Offline markdilljr
  • Me on Hopper "Covered"
what size bolts
« on: June 30, 2010, 07:45:27 pm »
What size bolts do I need if I am removing 2 leafs out of my rear springs, I have read that I need shorter bolts for where the springs sit on the saddle, I am picking up a used pair of leafs and am going to remove 2 leafs but there are no parts stores near where I am picking them up at or where I am working on it at, so I need to get the bolts before I head over that way. I am doing it in the mornin so any help would be great thank you
Ride Rank, Make Bank
Offline Grim 82
Re: what size bolts
« Reply #1 on: July 01, 2010, 11:16:02 am »
Are you talking about U-bolts? Re-use them as long as they don't interfere with anything and you have enough take-up on the threads to tighten them down.
« Last Edit: July 01, 2010, 11:24:25 am by Grim 82 »
Offline markdilljr
Re: what size bolts
« Reply #2 on: July 01, 2010, 02:16:51 pm »
No the bolt that goes through the springs to hold them together and aligns the spring with the saddle
Re: what size bolts
« Reply #3 on: July 01, 2010, 04:25:18 pm »
Google leaf spring pin bolt
Offline rtnowme
Re: what size bolts
« Reply #4 on: July 04, 2010, 08:41:41 pm »
5/16 fine thread mostly, just round the hex off small enough to fit the saddle hole if you have to replace
