Interior & Equipment
Heating, Ventilation & Air Conditioning (HVAC)
Blower motor only runs on HI...
Topic: Blower motor only runs on HI... (Read 10989 times)
K10NM
July 03, 2010, 06:00:27 pm »
I'm working on the interior of my 85 K10, and am having trouble with my heater/ac blower. The motor will only run on 'HI'. Where should I start looking to fix this problem? Thanks for any and all help!!!!!
85 Chevy K10
9" of total lift, 6 susp., 3 body
35x12.50x15 BFG all terrains
Shaved handles, tailgate, mirrors
Custom interior
rs74
Re: Blower motor only runs on HI...
July 03, 2010, 10:50:38 pm »
Sound like it could be the blower motor resistor. Usually when they only work on high it is the resistor.
K10NM
July 03, 2010, 11:23:51 pm »
Thanks for the reply!! I'll try to replace that as soon as I can, and let you know how it goes!!
85 Chevy K10
Custom interior
July 03, 2010, 11:47:26 pm »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=16395.0
Skunksmash
July 04, 2010, 02:02:59 pm »
Ha, my blower motor will only run on every setting
except
high. Kinda sucks.
TxFiddler
July 05, 2010, 04:01:31 pm »
I had the same problem, however, I did not need a new resistor. The wiring on the plug that goes to the resistor had become loose. Check the wires in the connector before you buy a new resistor.
80 C10 2wd / 427 BigBlock / 700R4 / 3:42 Eaton Posi LSD / 770 cfm Holley Street Avenger / Doug's Headers / MSD ProBillet Distributor / Champion 3 row Radiator
Skunksmash
July 05, 2010, 06:18:13 pm »
What resistor are you guys talking about? Anyone happen to have a pic of its location, or what it looks like?
July 05, 2010, 06:27:25 pm »
Read the post I posted
mrboyy17
July 06, 2010, 12:14:28 pm »
when i bought my truck i had the same problem. however mine was fixed by changing the relay....not the resistor. i bought a new resister too but never put it on cuz the relay fixed the problem.
mark
K10NM
August 12, 2010, 04:27:54 pm »
Just wanted to say thanks to all for your help! I was finally able to get around to fixing the blower problem. It was the relay that was bad. Thanks again, I now have a normal working blower fan!!!
85 Chevy K10
Custom interior
