Author Topic: Bondo (evercoat z grip) question  (Read 3691 times)
Offline liftedchevys87
« on: July 05, 2010, 04:19:04 pm »
I left a gallon (half full) of Evercoat Z Grip body filler with the lid a bit off for probably about a week. I just noticed it  :-\, I intend to use some more of it to finish my body work. I'm not sure if this will effect the outcome of the body work if the semi open can let humidity in the body filler. The texture of it seemed pretty much the same, maybe a tad bit harder. I would like to use it, but what do you guys think?
- 87 1/2 ton 350 4x4
- 78 1/2 ton 454 flat bed 2wd
Re: Bondo (evercoat z grip) question
« Reply #1 on: July 05, 2010, 05:34:54 pm »
It's slightly hygroscopic so I wouldn't use it if you think it's saturated. I know lots of guys that never put the lids back on tight though and re-use it.
Offline 80stepsideguy
« Reply #2 on: July 05, 2010, 08:10:31 pm »
Take a paintstick n stir it up good as  long as its soft enough to stir your ok. If its pretty hard its no good..
thanks
pat
1998 Chevy 1500 S/B 2wd
