Author Topic: so here is my 77 K20  (Read 20569 times)
Offline 77 K20 Silverado
« on: July 13, 2010, 02:21:11 pm »
Do not have a lot of before pics but plenty of afters
here is the engine
and in the background
And the after
Went through the whole motor, rebuilt the startor, alternator, and powersteering pump
The only thing I did not do my self is the carb that went out now I'm waiting on the kit to rebuild the A/c compressor
Re: so here is my 77 K20
« Reply #1 on: July 13, 2010, 02:26:09 pm »
A/c compressor still needs to be rebuilt but just wanted to see it on.... the bracket mounted to it is for the plow pump
Offline Grover 1
« Reply #2 on: July 13, 2010, 02:37:07 pm »
What a difference!!  I like the look, and the old school oil filler in the intake.  I'm also not a fan of chrome, paint shows much more detail so your mill is aces with me.
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
And here I sit so patiently
You have to pay to get out of
« Reply #3 on: July 13, 2010, 03:02:49 pm »
Thanks, this truck is going to be a driver so chrome is low on the list for me
when i got it the front d44 was toast so I found a good Dana 60 to go with the GM14 bolt
The 60
And 14 Bolt primer only
Next step is to sand blast frame, rebuild the SM465 and NP205 and get the drivetrain done
Rob
Offline mitch sonsteng
« Reply #4 on: July 14, 2010, 08:23:26 am »
Hey man, its lookin good!
« Reply #5 on: July 15, 2010, 12:23:47 am »
Way awesome!
So, why does it look like your fan blades have uneven spacing?
« Reply #6 on: July 15, 2010, 02:39:58 pm »
All of the factory fans do.
« Reply #7 on: July 15, 2010, 05:18:45 pm »
have no idea what the deal is with the fan, but Ive not seen to many that do have even spacing kinda weird
Rob
« Reply #8 on: July 16, 2010, 01:08:18 pm »
I havent seen too many factory fans. What is the reason for it?
« Reply #9 on: July 16, 2010, 03:21:32 pm »
as I understand it it makes less noise with the blades uneven like that
Rob
« Reply #10 on: August 12, 2012, 12:02:09 pm »
Sorry its been a long time I did not like the frame I had so I found a '78 1 Ton frame to use. I sandblasted it epoxy primed and then painted it
« Reply #11 on: August 12, 2012, 12:07:29 pm »
Tore Down the Transmission and transfer case to be rebuilt and got them all painted
« Reply #12 on: August 12, 2012, 12:16:02 pm »
Same thing with the steering gear. took it apart and rebuilt it, then fresh coat of paint. Had a problem with the K20 axle not fitting onto the K30 frame, the springs mount closer together on a 1 ton. nothing a grinder and welder cant fix. the worst part was it was all painted and ready to go in. I was able to get the 13" brakes from a k30 also.
« Reply #13 on: August 12, 2012, 12:24:57 pm »
Now everything is back together, I had to find new rear springs. otherwise everything went right in. now it is time for body work.
Offline rmauto1
« Reply #14 on: May 13, 2013, 07:38:26 am »
Any update??
