Author Topic: water temp sender 82 C10  (Read 6405 times)
Offline greatdane
« on: July 13, 2010, 03:47:28 pm »
What does the water temp sender look like for the factory temp gauge? Someone took mine out. Its my 82 C10 H vin# 305/th350! I bought one from autozone not sure if it right?
'74 AMC Matador 2dr Coupe
Re: water temp sender 82 C10
« Reply #1 on: July 13, 2010, 08:21:00 pm »
Offline greatdane
« Reply #2 on: July 13, 2010, 08:37:25 pm »
Thanks.... They gave my a water temp sensor instead of a sender!? I got it changed out. Originally I think mine was the second one from the left. They gave my the far right one. I will just change female connectors I guess.?!
« Last Edit: July 13, 2010, 08:42:46 pm by greatdane »
Offline greatdane
« Reply #3 on: July 13, 2010, 10:49:08 pm »
Welp, I just took my new oil filter adapter out of the box and no freakin bolts!!! U know what size are they are?
« Reply #4 on: July 13, 2010, 11:12:41 pm »
Shouldn't it come with bolts?
Offline greatdane
« Reply #5 on: July 14, 2010, 08:30:24 am »
Not this one!
« Reply #6 on: July 14, 2010, 09:28:31 pm »
So you know for a fact that the manufacturer of the adapter does not supply bolts? Or are you assuming it because it just didnt come with any?
I would maybe go down to the parts store and ask to see if they have one in stock. If it has the bolts, you can figure out which ones you need.
Offline greatdane
« Reply #7 on: July 15, 2010, 03:21:22 pm »
Used some stainless allen head bolts from work 5/16! Its on there......
« Reply #8 on: July 16, 2010, 01:05:45 pm »
Good deal.
