Author Topic: need help identifying wires  (Read 6862 times)
Offline txchainsawgogi
« on: July 14, 2010, 12:42:40 pm »
1978 C10 5.7L
Thought I had this posted but now I can't find it? Kinda weird. Anyway I'm trying to figure out where these wires are supposed to go. Two connectors with two wires in each coming from the firewall.
Also found this, chewed threw by a rat or mouse, lying below the radiator?
Any help would be appreciated!
Offline hotrod24
Re: need help identifying wires
« Reply #1 on: July 14, 2010, 03:47:24 pm »
The two top ones would be the washer pump...
1978 pontiac grand prix...
Offline Grim 82
« Reply #2 on: July 14, 2010, 04:36:53 pm »
The other one with the single wire and rubber boot plugs in near the frame rail right by where the power steering lines clamp to the frame, but I am not sure what it is for.
Offline hotrod24
« Reply #3 on: July 14, 2010, 04:58:40 pm »
yep it goes right here...
« Reply #4 on: July 14, 2010, 05:24:27 pm »
What the heck! What does that single wire go to???
Offline hotrod24
« Reply #5 on: July 14, 2010, 05:49:39 pm »
I think it goes to your oil pressure sensor...
Offline ccz145a
« Reply #6 on: July 14, 2010, 07:30:49 pm »
It goes to the brake warning light on mine.
« Reply #7 on: July 14, 2010, 09:33:02 pm »
I found where it plugs in, there's a spot under the radiator on the right hand side(facing the engine).  Just like in hotrod's photo. Def. not a ground... hmm...
Offline werewolfx13
« Reply #8 on: July 14, 2010, 09:54:01 pm »
Its the brake line pressure warning light.
Chris
'83 Chevy c10 Silverado SWB
