Author Topic: Lifting With Diffrent Axles  (Read 6225 times)
Offline frickenbored
  • 383 Beast
« on: July 15, 2010, 09:51:52 am »
Well its time for me to lift my 1988 K5 Blazer but theres a problem.  I just want to do a 4" lift but I swapped the rear 10 bolt for a 14 bolt and my front 10 bolt for a dana 44.  I'm pretty sure that the dana 44 and 10 bolt are basically the same so I can get a normal 88 blazer front lift.  My question is where can I get a kit that only comes with the 4" lift for the front and where can I get a kit that only comes with 14 bolt 4" blocks?
Re: Lifting With Diffrent Axles
« Reply #1 on: July 15, 2010, 11:39:28 am »
If the parts would be different, most lift companies sell parts individually.
« Reply #2 on: July 15, 2010, 02:25:07 pm »
Should mount up the same.  if they are axle specific call whomever you are getting if from when you order.
  • 383 Beast
« Reply #3 on: July 15, 2010, 09:42:04 pm »
so the 4" blocks for the 10 bolt are the same as the 4" blocks for the 14 bolt?  If they are that would be great...as for the u-bolts I can get those anywhere.
« Reply #4 on: July 16, 2010, 12:43:01 pm »
10-4
  • 383 Beast
« Reply #5 on: July 16, 2010, 06:05:07 pm »
Yea it just dawned on me today...the reason I'm swaping the 14 bolt in is because the perches are exactly the same and I don't have to change anything but the u-bolts.  So of course the blocks are the same, duh.  Thanks guys
