Engine/Drivetrain
TBI to Carb
Topic: TBI to Carb (Read 3732 times)
txswb87
TBI to Carb
July 18, 2010, 04:15:30 pm »
ok I'm going from a TBI computer engine to non computer, On my 87 SWB. I have the trans. taken care of for lockup. Has anyone pulled the computer out? How hard will this be? Any help would be greatly appreciated.
award280
Re: TBI to Carb
July 18, 2010, 07:35:36 pm »
IM sent.
Re: TBI to Carb
July 18, 2010, 08:09:22 pm »
What exactly are you trying to do? If you're just putting a carburetor on it it doesn't have to come out. All you need is a carb and an HEI
txswb87
Re: TBI to Carb
July 18, 2010, 08:46:00 pm »
I'm taking out the 5.7 and putting in a 383. I have installed the TCI kit in the trans. for the lockup. I wanted to pull out the computer but wasnt sure what componets were run of of it ie; gauges,A/C heat,fuel any help is appreciated at this point.
Last Edit: July 18, 2010, 08:51:56 pm by txswb87
Swims350
Re: TBI to Carb
July 19, 2010, 10:52:43 am »
from what I know with the older tbi stuff the computer is of course for the lockup on the trans only and the engine functions so it'd be easy to remove.
As said before you need the carb and hei dist. and a fuel pressure regulator or switch to a block mounted pump if the block is drilled to accept one.
www.cardomain.com/id/benwa454
Engine/Drivetrain
TBI to Carb
