Author Topic: No start at work last week  (Read 5514 times)
« on: August 01, 2010, 06:34:43 pm »
Just figured I would share a little something from work.
 Had a 2001 Chevy 2500 come in on the hook last week. Died driving down the road, wouldn't restart. Checked for fuel pump noise, had it. Checked for spark, had it. Ran the MODUS checked for codes, had no codes at all. Checked fuel pressure above 60 PSI. Took the cap off found it to be a little crusty, have seen much worse still run. Swapped in a new one anyway, she fired right up!! Threw in new plugs and wires too as they were the factory ones with almost 90,000 on them.
 Sometimes its the smallest things!  ::)
Offline frotosride
    • WFO CONCEPTS
Re: No start at work last week
« Reply #1 on: August 02, 2010, 11:16:40 pm »
smallest things for sure...one of my ants had 18k+ on her truck never changed oil...and u guessed it..welded pistons to the bores. smallest things!!
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: August 03, 2010, 12:04:02 am »
Quote
You mean the oil needs to be changed often?  Man, I guess I know what I'm doing tomorrow.  And plugs supposed to be changed.   Man, my work is cut out for me.   ;D
You gotta love the simple fixes, but, those all come with time and sperience.  I would've been boggled on that for about a week.
« Last Edit: August 03, 2010, 12:05:54 am by SgtDel »
Offline Layne
« Reply #3 on: August 03, 2010, 12:47:21 am »
I like the leakers and burners- just the filter every 3000.  ;) ;D
Offline frotosride
    • WFO CONCEPTS
« Reply #4 on: August 04, 2010, 09:31:54 pm »
noted :D remind me never to buy anything from you... ;D
Offline Layne
« Reply #5 on: August 05, 2010, 01:04:53 am »
My Dads famed quote. He gets mad when I change the oil in my car after I put in 5 quarts thoughout 3000 miles then another 4 to change it
