Author Topic: help installing new distributor.  (Read 26901 times)
Offline txchainsawgogi
« on: August 08, 2010, 06:59:47 pm »
Got the radiator situation all sorted out all thanks to y'all. Next on my list is upgrading my old, neglected distributor/rotor/plug wires.
If I want to run an msd ignition box, what combo should I use that's cheap and effective...that go together well?
« Last Edit: August 19, 2010, 05:08:55 pm by txchainsawgogi »
Re: next on the list, distributor/rotor upgrade questions!
« Reply #1 on: August 08, 2010, 11:30:58 pm »
For example, what's the difference between the MSD "street fire" distributor model 8362 and the "pro billet" model 8365?
I can get one for 75+ shipping and the other I can't find under 250$
If the street fire model is compatible I might run it... anything is better than a 30 year old stock setup right?
1978 C10 5.7L 350ci
« Last Edit: August 08, 2010, 11:40:11 pm by txchainsawgogi »
« Reply #2 on: August 09, 2010, 09:22:11 am »
I kept my hei on my 79 it normally doesn't go above 3k in less I'm in the mud then it barely touches 4. If your not racing it in the high Roma then I see no need for mad but that's just me
« Reply #3 on: August 09, 2010, 10:00:19 am »
So should I just replace the cap and rotor?
« Reply #4 on: August 09, 2010, 10:02:20 am »
Do you have an MSD ignition system?
« Reply #5 on: August 09, 2010, 01:18:47 pm »
Its stock. So an msd distributor cap isn't compatible with stock? I want to upgrade everything but keep the costs down.
« Reply #7 on: August 09, 2010, 07:29:39 pm »
Haha a bit flashy...will that work out for me? Not too cheaply manufactured?
« Last Edit: August 09, 2010, 07:38:59 pm by txchainsawgogi »
« Reply #8 on: August 09, 2010, 07:57:19 pm »
Yes it will work and it may not be like msd but its all you need
« Reply #9 on: August 09, 2010, 08:54:29 pm »
What should I get to go with it? It'll work with the stock hei?
« Reply #10 on: August 09, 2010, 10:07:14 pm »
That eBay store has other cap colors. Black, red, blue, etc.
« Reply #11 on: August 09, 2010, 11:40:39 pm »
« Reply #12 on: August 10, 2010, 01:29:45 am »
It appears it gets rid of the HEI...so it wouldnt be compatible.
« Reply #13 on: August 10, 2010, 03:18:41 am »
if you want that procomp kit it will replace everything thats all you need but IMO thats more things that could fail then you will be stuck for a while waiting on parts to come in nut with the one vile posted they also replace your stock hei with aftermarket but if the aftermarket fails its the same as stock and you can get back on the road faster
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #14 on: August 10, 2010, 09:20:08 am »
http://cgi.ebay.com/ebaymotors/NEW-SBC-BBC-CHEVY-CLEAR-CAP-65K-HEI-DISTRIBUTOR-6500-CL-_W0QQcmdZViewItemQQitemZ330437648862QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
I bought that one....   It looks awesome.  I took it apart some and everything looks really nice, it spins easily, etc...    Havent tried it out yet though, its for when I get my new engine.   So far though I'm happy with its appearance.
As far as an ignition controller, I'd just Get an MSD 6A.  The distributor you use with it doesn't matter, as long as the components arent too worn out.
« Last Edit: August 10, 2010, 09:22:56 am by 78 Chevyrado »
