automatic trans floor shift conversion
Topic: automatic trans floor shift conversion (Read 26795 times)
txchainsawgogi
August 13, 2010, 11:54:50 pm »
How easy would it be to install a floor shifter? I found a few universal cable operated ones that look nice... I've always liked floor mounted shifters more appealing than on the column.
Is it a pretty easy mod, or would I have to go into the tranny at all?
78 C10 350 (auto 2WD)
Layne
Re: automatic trans floor shift conversion
August 14, 2010, 12:01:34 am »
It's not too bad. I've got a B&M ratchet in mine; all I had to do was hook up the cable and adjust and mount it to the floor
team39763
August 14, 2010, 08:18:32 am »
It's a easy mod to do. If I remember correctly, you just need a drill and something to make a bigger hole in the floor for the cable to go through. Just follow the directions and you'll be fine. I have the Hurst Promatic2 in my truck, it's a ratchet shifter.
txchainsawgogi
August 14, 2010, 08:53:12 am »
Awesome..ill add that to my list after paint, but before a sound system haha
txchainsawgogi
November 28, 2010, 08:24:46 pm »
So would I have to cut a large hole in the floor? I'm confused on how the cable attaches to the transmission.
Also, back up lights?
Layne
November 28, 2010, 08:41:01 pm »
I cheated.... I left part of my column shift on and moved it down when I went to reverse
You don't have to make a huge hole; just one large enough to go through the floor. The shifter will cover the hole.
txchainsawgogi
November 28, 2010, 10:31:18 pm »
Haha well I want to completely clean up the column... I'm worried I'll have trouble with hooking up the reverse lighting!
topp
November 28, 2010, 10:48:24 pm »
I think some shifters, like B&M, come with reverse switch and a neutral safety switch
'90 Suburban TBI 350
Psycho71
November 30, 2010, 08:34:20 am »
Not really a hard job at all. The instructions with the shifter will guide you through the whole process. As for reverse lights and neutral safety, just check the feature list on the prospective shifter. It will/should list any and all features the shifter has.
I installed the B&M Hammer in my '71. I mounted it in a custom console I built. But the process is the same as mounting it in the floor. No problems getting it to work.
November 30, 2010, 11:26:28 am »
http://static.summitracing.com/global/images/instructions/bmm-ltmegashifter.pdf
Cody1018
November 30, 2010, 02:34:00 pm »
Anybody have any pictures of this conversion? Interested in how it looks.
1986 Chevy K10 Silverado
November 30, 2010, 02:36:56 pm »
bigblock73 has this in his truck:
Psycho71
November 30, 2010, 07:19:59 pm »
Here's mine.
http://i49.photobucket.com/albums/f269/psycho0819/Truck%20Pics/IMG_1150.jpg
Last Edit: November 30, 2010, 07:23:23 pm by Psycho71
