Interior & Equipment
Heating, Ventilation & Air Conditioning (HVAC)
A/C question
Topic: A/C question (Read 8022 times)
454ss
I WANNA RACE IN A BIGFOOT TRUCK!
A/C question
August 16, 2010, 04:31:12 am »
This question may have to be answered by trial and error when I get a truck, but here goes in hopes maybe someone might have an answer.
Will a 1988+ A/C unit fit behind the dash of a 1973-87?
My idea here is that I want to put electronic climate control in a 73-87 truck using factory parts. Possibly using an Oldsmobile control unit as it appears to be similar in size to the original 1973-87 HVAC control.
Yes, you will find as we go along that I
am
certifiably insane.
Jay
Searching for my ideal 1973-87 fullsize.
1982 C10 Custom Deluxe stepside - traded
1977 C10 Custom Deluxe longbed - junked
Current:
1991 Chevy S10 Blazer 4x4
1995 Olds Silhouette
2009 Chihuahua
Re: A/C question
August 16, 2010, 06:12:51 am »
The question that I know of hasn’t been asked but the answer has been. "were there’s a will there’s a way" there’s some room under our dashes to do almost anything but you would need the guts out of the olds and find a way to mount or make your own duck work to attach the motors to open and close the flaps now the ac I don’t know anything about them but im sure their wires are separated and could be made to work with our trucks
DnStClr
Re: A/C question
August 17, 2010, 03:34:35 pm »
Wouldn't it be easier to buy a truck with a/c already installed 454? That's an agressive plan ya have there.
Don
87 Chevy Silverado
Re: A/C question
August 17, 2010, 05:17:03 pm »
Be advised you'd be looking at a lot of work for a very problematic system. The OLDS / Pontiac ATC AC climate controls are plagued with problems.
#1 The AC Programmer (AC Computer under the dash) is about $750 and are prone to failure.
#2 The control head displays burn out
#3 The actuator doors tend to break on the controller namely the temp blend door.
#4 The associated wiring is not stand alone - most of the systems communicate via the CAN BUS or serial data line through the PCM.
Bottom line is I could never see it worth your while to go through all of that to just be able to say you have a digital retrofit. There are aftermarket elcetronic climate controls that may be a better option but obviously more expensive.
454ss
Re: A/C question
August 17, 2010, 07:30:22 pm »
I've had 4 Cutlass Supreme convertibles (no BCMs in these) and none of them had problems with the ECC.
Actually, they are stand alone.
I'm thinking that if I use some stuff from a 1989-1993 GMT-400 and some from the Cutlass Supreme, it just might work.
I have a lot of extras from the Cutlasses, so that won't be a problem.
My other thing is that with using the Cutlass ECC, I wouldn't have to add a DIC (compass/temp) to the overhead console, the Cutlass already has an outside temp sensor and I have a rear view mirror with a compass already.
Jay
Current:
2009 Chihuahua
Re: A/C question
August 17, 2010, 07:59:29 pm »
Well if the parts are plentiful and you are using a standalone system then it's doable. Plus if you have an extra dic you should be able to get it all done
Keep us updated
A/C question
