Author Topic: Rear defrost?  (Read 6490 times)
Offline 454ss
  • I WANNA RACE IN A BIGFOOT TRUCK!
Rear defrost?
« on: August 16, 2010, 04:35:37 am »
I know 1988+ extended cabs and 1992+ crew cabs were offered with rear defogger, were the square body pick ups available with it?
Jay
Searching for my ideal 1973-87 fullsize.
1982 C10 Custom Deluxe stepside - traded
1977 C10 Custom Deluxe longbed - junked
Current:
1991 Chevy S10 Blazer 4x4
1995 Olds Silhouette
2009 Chihuahua
Re: Rear defrost?
« Reply #1 on: August 16, 2010, 06:08:43 am »
now that you mention it I don’t think I ever saw a 73-87 but im sure I haven’t seen a 88-98 with it either so that doesn’t mean nothing
Offline Psycho71
Re: Rear defrost?
« Reply #2 on: August 16, 2010, 04:13:00 pm »
I can't recall ever seeing one either. But I'm pretty sure there are add-on rear defrosters available.
Re: Rear defrost?
« Reply #3 on: August 16, 2010, 04:55:09 pm »
No, not from the factory.
Re: Rear defrost?
« Reply #4 on: August 16, 2010, 06:25:19 pm »
Suburbans and blazers did
Offline 454ss
Re: Rear defrost?
« Reply #5 on: August 17, 2010, 12:31:14 am »
I came across a 1989-93 extended cab 3500 with what appeared to be factory rear defrost. The switch was the same as in a 1992-93 Blazer/Sub and had lines on the back window.
So i naturally wondered if the square bodied 1988-91 crew cabs had one optional...I'd add it if they did...Fieros had it, why not trucks?  ;D
Along the same lines, I need to see if there's a heated (and hopefully autodimming) mirror glass that will fit the factory power mirror housings.  8)
Jay
Current:
2009 Chihuahua
Re: Rear defrost?
« Reply #6 on: August 17, 2010, 12:55:50 pm »
The 89-91 power mirror use the same glass/head as the 88-9? and Astro vans I believe, so if they are in those years you can swap them.
