Interior & Equipment
dash swap
Topic: dash swap (Read 13526 times)
big.45
dash swap
August 24, 2010, 02:06:40 pm »
I have an 80 gmc and want to put in the newer 81-87 dash.
Can I do this, and what all will I have to change?(Gauage cluster, bezel)
454ss
I WANNA RACE IN A BIGFOOT TRUCK!
Re: dash swap
August 24, 2010, 07:35:56 pm »
Everything is a bolt in. I don't think there were any changes in gauge wiring either.
Jay
Searching for my ideal 1973-87 fullsize.
1982 C10 Custom Deluxe stepside - traded
1977 C10 Custom Deluxe longbed - junked
Current:
1991 Chevy S10 Blazer 4x4
1995 Olds Silhouette
2009 Chihuahua
Swims350
Re: dash swap
August 24, 2010, 08:07:16 pm »
ok when you say dash what part do you mean the soft top dash pad? the cluster of gauges, the gauge surround?
www.cardomain.com/id/benwa454
Re: dash swap
August 24, 2010, 09:55:49 pm »
If you are referring to the pad, you will need to change many things. Nothing will interchange correctly without a few swap items. The 1980 dash bezel gauge cluster mount and alignment will be off with the 81 up dash, wiper switch would have to use an early bezel, the pad, the insert panel, and a few other minor differences. Why do you want to change it anyway?
big.45
Re: dash swap
August 25, 2010, 12:56:20 pm »
I need a new dash pad, this one has a cap on it and the whole thing is twisted and looks bad. I saw I could get a factory new one from the website for 81-87, and I like the look of them. I haven't seen new dash pads for the 80.
I know I will need a dash bezel 81-83.
Will I also need the part that holds the gauges that bolts to the dash(the white piece)?
What other Items would I need?
Would it look factory once I got all the parts required?
Old77
Re: dash swap
August 25, 2010, 01:24:02 pm »
As far as looking stock, it should as long as you do it correctly and get all the necessary parts that you need. If it was me, I'd look really hard at just getting a correct dash pad for 1980, though, as moving up to an 81-87 is not a significant improvement compared to the work that'd be involved. just my .02
Last Edit: August 25, 2010, 04:10:58 pm by Captkaos
www.chevygmcofkc.org
'77 build thread:
http://www.chevygmcofkc.org/forums/showthread.php?1728-Working-on-the-77-once-aga
Swims350
Re: dash swap
August 25, 2010, 02:36:39 pm »
the 81-87 door panels match the 88+ dashes and vice versa, so in order to look factory the door panels need switched too. I'd look into making the cap fit it, or straighten yours out first. If not search online or ebay or google for a 73-80 dash pad.
Re: dash swap
August 25, 2010, 04:12:35 pm »
Cheyenne pickup has the best quality skinned 73-80 dashes last time I checked.
Re: dash swap
August 27, 2010, 10:06:28 am »
I would go with the 73-80 dash. It has a nice classic look and I found a mint NOS one on eBay a few months back for about $250 bucks that I bought.
Swims350
Re: dash swap
August 27, 2010, 07:39:57 pm »
I agree I love pretty much everything about a 73-80.
dash swap
