Author Topic: Heat/Sound insulation  (Read 4607 times)
Offline GUITAR1989
« on: August 27, 2010, 05:08:18 am »
Hey guys im looking into heat and sound dampening materials and alot of the well known brands are just out of my price range. ive seen videos on the heat resistant and sound dampening capabilities of them and im really impressed. Im just wondering if i can achieve the same effects for a lower cost. Would it be worth it to fork out the cash for B-Quiet, Dynamt... or can i get a decent heat barrier/sound dampener somewhere else for less. honestly all those products look like is aluminum and rubber :P what do you guys use in your trucks?
Offline Edahall
Re: Heat/Sound insulation
« Reply #1 on: August 27, 2010, 01:37:18 pm »
Read the following link.  Use what you learn and buy the products on your own from lower cost vendors.
http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
The cheapest place I have found for the MLV is here:
http://www.soundproofing.org/infopages/flooring.htm
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
