Author Topic: 90 crew cab 1/2 ton SWB.. 3/5 drop... what factory rear shock can I use?  (Read 4529 times)
Offline bigtime
  • New Users
I have a 1990 1/2 ton crew cab  (Square style). When I bought it, it had a flip kit in the rear with 3" drop spindles. It rode VERY rough, So I removed the rear shocks which were bottomed out. It now rides smooth as silk but rides like a truck with no shocks. BOUNCY.... I have a buddy who said I could have someone look up the length of the factorys at a parts store and find me some 5" shorter off of another factory vechicle. I was wanting to know if any of you have run into this and knew what vechicle they would come off of.
Thanx
Bigtime
You should be using drop shock brackets or lowering shocks, either of which you can get from Summitracing.com
Offline y2k_harley
I used some off of a 70 Chevy C10 with coil spring rear.  They are shorter, but I don't think 5" though.
Offline three8six
I remounted the shocks to the lower side of the rear axle on some custom brackets
