Author Topic: 2 gauges quit working  (Read 6852 times)
Offline southdakota85chevy
« on: August 27, 2010, 09:18:44 pm »
both my gas gauge and my temp gauge are now suddenly reading too high, from what ive heard it could b caused by the voltage regulater in my alternater, but my voltmeter seems to b ok and it charges fine, guess im not sure what to think
Offline 454ss
  • I WANNA RACE IN A BIGFOOT TRUCK!
Re: 2 gauges quit working
« Reply #1 on: August 27, 2010, 09:29:42 pm »
Have your alternator tested, many auto parts stores have the ability.
Then check your dash grounds as well as the printed circuit board on the cluster.
Jay
Searching for my ideal 1973-87 fullsize.
1982 C10 Custom Deluxe stepside - traded
1977 C10 Custom Deluxe longbed - junked
Current:
1991 Chevy S10 Blazer 4x4
1995 Olds Silhouette
2009 Chihuahua
« Reply #2 on: August 27, 2010, 09:32:31 pm »
If they both started acting up at the same time I would start at the cluster and clean your connections at the printed circuit.
« Reply #3 on: August 28, 2010, 12:21:13 pm »
alternator tested out fine, geting frustrated, were are the dash grounds located?
« Reply #4 on: August 28, 2010, 12:26:38 pm »
If I were a betting man you are going to find a burnt spot on your printed circuit board on the back of your instrument cluster.  I had mine go out, a quick trip to the pick-n-pull and $35 lighter in the back pocket I got a nice one that had a quartz clock.
« Reply #5 on: August 28, 2010, 10:10:48 pm »
As you've heard us say - CHECK THE PRINTED CIRCUIT
« Reply #6 on: August 29, 2010, 12:32:05 am »
the printed circuit has a ground and everything else it should be the problem as vile keeps saying lol
« Reply #7 on: September 03, 2010, 08:50:15 pm »
well printed circuit seems to b fine, cant find any problems there..., think im guna hav to break down and take it in to someone who can do a ltl more testing than i can, frustrating
« Reply #8 on: September 04, 2010, 03:27:25 am »
make sure your ground on the circut board is good use a ohms tester and test the plug ground then plug it in and test the gnd on the board make sure they both read good
