Author Topic: dana 44 6 to 8 lug  (Read 5330 times)
Offline 76 k10
dana 44 6 to 8 lug
« on: September 05, 2010, 04:05:16 am »
i have a dana 44 that is a 6 lug and i would like to do the 8 lug swap. does anyone no what all i need and where i can get it? and will A dana 60 out of a dodge work in my 76
Re: dana 44 6 to 8 lug
« Reply #1 on: September 05, 2010, 04:20:14 am »
I would grab a Dana 60 front and rear out of a dodge I think it would be cheaper for one and two after you change the front to 8 lugs then you have to change the rear to 8 or change out the whole rear. The 60 from what I was told by someone on here was its a little smaller width between the perches but it will fit just kind of squeezes the leafs inward
« Reply #2 on: September 05, 2010, 09:54:37 am »
regardless if he swaps a 60 in or converts his 44 he will still have to swap rearends for the 8 lug pettern.
In order to swap it over to 8 lug you will need everything from the knuckle / ball joints out from an 8 lug Dana 44. it will all bolt directly on to your knuckles.
If it was me I would swap in the 60 from the Dodge.
Offline 76 k10
« Reply #3 on: September 06, 2010, 04:16:18 pm »
i already have a 14bolt with a locker so im not worryed about that. but will a dodge bolt up?
« Reply #4 on: September 06, 2010, 09:12:05 pm »
Yes
