Author Topic: carbarator spring  (Read 6129 times)
Offline Buddy
carbarator spring
« on: September 09, 2010, 08:02:16 pm »
I am trying to re install my carb on my 305. I see that there is a spring where the throttle cable and kick down cable go. I have the spring but cant see to figure out how the spring is supposed to attach to make it spring loaded. Can someone post a pic. I think i miight be missing a bracket or something
Offline Layne
Re: carbarator spring
« Reply #1 on: September 10, 2010, 12:15:04 am »
You might have to McGyver something. I took a hose clamp to my upper rad hose and hooked it there.
« Reply #2 on: September 10, 2010, 01:43:12 am »
     What carb. is it ?  Most of the time one end mounts to the lever that the throttle cable is on, and the other is attached at the back of the carb. off another bracket.  If we know what carb. it is someone can post a pic I am sure....Tom
Offline Buddy
« Reply #3 on: September 10, 2010, 08:11:44 pm »
holly carb, not sure of size. I dont know how to tell on the size
« Reply #4 on: September 10, 2010, 08:14:45 pm »
Check for a model number and look it up.
Offline Stewart G Griffin
« Reply #5 on: September 13, 2010, 01:09:08 pm »
This is a stock 83 setup for Q-jet;  i don't know if it will help.
Which Holley do you have?
Offline Buddy
« Reply #6 on: September 14, 2010, 06:21:38 am »
650 holly
« Reply #7 on: September 14, 2010, 06:25:00 pm »
Can you see a model number?   650 is the cfms, which we don't care about at this point.
« Reply #8 on: September 15, 2010, 02:44:31 am »
like stew posted one end hooks to the bracket the other to the throttle. both my hollys go the same way
