Author Topic: Best choice for manual conversion?  (Read 5400 times)
Offline Gearhead1
  • Its not much, but its all I've got
« on: September 13, 2010, 07:32:47 pm »
I'd like to swap out the TH350 for a 4 or 5 speed manual trans for my SWB R10...Do camaro 5 speeds swap over and do they withstand some abuse?? I have a line on a cheap Saginaw, but I dont think that would last too long...besides a Muncie, any suggestions on reasonably prices gearboxes that arent granny trannys?
Re: Best choice for manual conversion?
« Reply #1 on: September 13, 2010, 07:43:12 pm »
If I were doing to convert I would go with a 6 speed
« Reply #2 on: September 13, 2010, 08:05:54 pm »
For a budget minded manual conversion a parts truck is usually the most inexpensive route to take although may be harder to find.  If you find a truck same wheelbase as yours and a 3 speed stick that is always a great starting point.  You can direct swap an older Muncie M20 in its place down the road.  Somewhat rare is a MY6 optioned 4 speed overdrive, 4th gear being the overdrive.  You will get mixed feelings here on that trans as far as durability but keep in mind I am only thinking of the budget way to go.  Obviously if money is no object that Vile is correct but I won't have that much into my whole truck when I am done as that transmission costs.  My $.02
Offline Altec
  • Custom De-Luxe
« Reply #3 on: September 13, 2010, 08:13:55 pm »
No Muncie?  :'( Not even a M22? Rock Crusher? Not a granny tranny!
Well, you can check out the Tremec T56. It is a 6-Speed found in a bunch of things. Solid transmission. Might be able to find one at a Pick-In-Pull.
The Camaro 5-speed would probably be fine if your Turbo 350 held. But I wouldn't want to try to put even a build 327 in front of it.
1981 K10 Short Bread - 6.5NA - SM465
« Reply #4 on: September 13, 2010, 10:24:46 pm »
What is your budget when you say reasonable price?
What is the intended abuse you are describing?
« Reply #5 on: September 13, 2010, 10:40:18 pm »
Have never seen any of the stock 5 spds. hold up to much abuse.
Offline Edahall
« Reply #6 on: September 13, 2010, 11:43:46 pm »
For abuse, nothing matches an NV5600.  I have this transmission behind my Cummins diesel.  The second best would be an NV4500 but 5th gear is a little weak with a healthy high torque engine.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline Gearhead1
« Reply #7 on: September 14, 2010, 07:43:48 am »
Thanks folks. My budget is pitiful...hoping for a complete trans under $ 1000. Muncies are scarce around here and pricey if available.
As for "abuses", I was referring to some occasional hard launches off the line sort of thing. The norm would be some cruising and pulling the occasional trailer...so something all purpose but solid.
I know automatics are the norm, but I've always liked driving manuals in both cars & trucks much more.
