Author Topic: 1987 chevy 1500 with cummins blinker and lights dont work right  (Read 17765 times)
Offline 1987chummins
« on: September 14, 2010, 09:10:18 pm »
Ok I did a complete body off resto-mod "sort of" on my 87 chevy 4x4 truck. I have all the wires hooked up and when I hit the brakes the gauge lights come on and clearence lights light up and when I let off they go off. When I hit the left side blinkers all the outside lights blink with it. When I hit the right side just the right side works like normal. I cant figure out what it is and it has me stuck and ready to carry to a guys shop that fixed some wiring foes on a past truck."which I hate having other people work on my baby". any help will be appreciated and yea it has a 93' cummins 6bt/chevy nv4500
Offline fred75
Re: 1987 chevy 1500 with cummins blinker and lights dont work right
« Reply #1 on: September 14, 2010, 09:42:27 pm »
  You really need to get your hands on a schematic??
'82 C-10 305/TH350-TCC EDL PERF INT W/1406 AFB MSD-6A HDRS
« Reply #2 on: September 14, 2010, 09:48:54 pm »
Ive looked at the schematic four times now and thats how I found out the flasher was out. I replaced it and now had this problem everythings hooked up correctly just acts like a bad ground or something
« Reply #3 on: September 14, 2010, 10:06:54 pm »
    If you checked the wiring diagram and everything is right then something is crossed wired or hooked up wrong.  sometimes it's best to walk away for a day or two and then tackle the job again.  My other suggestion would be to get a second pair of eyes on it.  Sometimes you get so focused on 1 thing that you overlook something, or it's right in front of you and you can't see it.  Happens to me at work sometimes......Tom
« Reply #4 on: September 15, 2010, 02:38:32 am »
Sounds like a ground problem. Did you redo the wiring in the cab or anywhere?
« Reply #5 on: September 15, 2010, 06:20:15 am »
Have you mixed and matched harnesses from different years? Is the steering column or from a different year?
Should be several grounds on the e brake bracket, one behind the left tail light, one from the block to the cab, one from the negative term to the core support above the right head light, and to the frame, one from the nose harness to the core support above the left head light. I'm sure i am forgetting a couple.
« Reply #6 on: September 15, 2010, 08:41:37 pm »
The only thing that i have done is put a new front clip and put a diesel gauge cluster in it. I havent messed with any of the wires inside. Today i tried messin with it and still no worky only the right signal works correctly. But still the same when hitting the brakes
« Reply #7 on: September 15, 2010, 08:55:07 pm »
Put the gas gage cluster back in and see if it solves the problem?
« Reply #8 on: September 15, 2010, 09:16:13 pm »
I swapped the diesel gauge in today. So that shouldnt be the problem cause they still dont work
« Reply #9 on: September 15, 2010, 09:43:19 pm »
Hmmm, I got nothin!
« Reply #10 on: September 15, 2010, 11:49:26 pm »
Check your grounds up front since you did take it apart. Did you change years with the front clip
« Reply #11 on: September 16, 2010, 10:43:24 am »
I put a 85 front clip but used my 87 wiring harness
« Reply #12 on: September 16, 2010, 10:51:00 am »
The part about the brake lights are stumping me but a bad ground will cause all sorts of problems
Offline Grim 82
« Reply #13 on: September 16, 2010, 11:12:35 am »
Do you have something else tied in to your brake pedal switch that shouldn't be? If the trouble starts when you hit the brakes I would chase that circuit and see what you find.
« Reply #14 on: September 16, 2010, 04:11:40 pm »
well guys I got a new problem. Since I have put a manual tranny I found a manual column and put that bad boy in there and guess what. MY PARKING LIGHTS WONT TURN OFF AND MY GAUGES ARE ON!! Ive tried everything on this dang switch and now Im really about to go kick the dented door on the parts truck... I have no idea whats goin on
