Author Topic: 1987 chevy 1500 with cummins blinker and lights dont work right  (Read 17766 times)
Re: 1987 chevy 1500 with cummins blinker and lights dont work right
« Reply #15 on: September 16, 2010, 04:28:02 pm »
Did you swap out the electronics on the column from the auto to manual?
What year column?  The changed a few times.
Offline 1987chummins
« Reply #16 on: September 16, 2010, 04:56:01 pm »
its off a 87 chevy and all the wirings the exact same
« Reply #17 on: September 16, 2010, 08:01:19 pm »
Figured out why the brake lights and running lights were on... When i pulled the column brake light switch popped out so brakelights on and te same problem persists with when mashin the brakes running lights come on.
« Reply #18 on: September 17, 2010, 12:48:51 am »
And now with messin with it all night i have brake lights that work right. And a right side blinker. The left side doesmt flash but comes up on the arrow. Also only the left side running taillight comes on no matter what i did to the right side even switched bulbs. Any ideas?
« Reply #19 on: September 17, 2010, 09:03:36 am »
When I switch from manual to auto to tilt to manual with no tilt I've always had to grind the plug on the column to make it work right but usually it was a ground wire on the plug not making contact.  But you problem has to be there
« Reply #20 on: September 17, 2010, 10:13:14 am »
On the blinker plug?
« Reply #21 on: September 17, 2010, 05:04:22 pm »
Yup has to. I think  ;D pretty sure
« Reply #22 on: September 17, 2010, 08:42:32 pm »
Mine fits pretty snug
« Reply #23 on: September 18, 2010, 12:28:12 am »
Mine would to but the contacts wouldn’t be touching right had to cut a half shape moon out of one end and a corner off the other and shorten it. Not saying it is your problem but kind of sounds like it
« Reply #24 on: September 18, 2010, 07:16:16 am »
Is the manual column from the same year truck? Every couple / few years the pin positions are different in the plug on the column, the gage cluster, the bulk head side of the fuse box etc. etc. All the problems you are describing sound to me like this could be the problem? For example, I have seen someone change a gage cluster, and just plug in the one with a factory tach. and nothing works correctly. I myself have swapped in a different year column, and had to pull the contacts out of the plug and reposition them in order to make directionals etc. work.
« Reply #25 on: September 18, 2010, 08:27:13 am »
I would take mine out andshow you what I had to do. But I wont dare do that took me forever to get it to work right
« Reply #26 on: September 18, 2010, 10:01:25 pm »
My uncle was telling me about something like that with some kind of adapter plug for it. Ill check it out tommorow
