Author Topic: Jimmy/Sub sending unit differences?  (Read 10461 times)
Offline Gearhead1
  • Its not much, but its all I've got
« on: September 20, 2010, 08:29:08 am »
I'm trying to find a sending unit for a custom tank I'm making. My parts dealer says the 40 gal Burb unit is worth $300 LESS than the Jimmy's 25gal tank unit. Is there a different lengths? (Deeper tanks? I just assumed they were longer)
Re: Jimmy/Sub sending unit differences?
« Reply #1 on: September 20, 2010, 06:08:03 pm »
If you're making a custom tank why are you using a suburban or jimmy sender?
Offline Gearhead1
« Reply #2 on: September 21, 2010, 11:06:46 am »
as opposed to an external pump set up?
I want to use it so the fuel level gauge works. I need to replace my crusty p/u unit and need an extra port for the vent. I'll add a separate port on top of the tank if I have to, but thats an extra step in the build. Trying to keep it simple
« Reply #3 on: September 21, 2010, 04:54:40 pm »
Then why not just use a Blazer tank and sender if you are trying to keep it simple?
Offline Gearhead1
« Reply #4 on: September 22, 2010, 06:35:27 am »
I want a simple set up for my custom tank. Fabricating is the easy part...its what I do.
I didnt want a paper thin factory tank - going stainless
« Reply #5 on: September 23, 2010, 02:45:30 pm »
40G is deeper than a 25G
« Reply #6 on: September 23, 2010, 04:09:34 pm »
In that case just fabricate the float arm since that's the only difference. Is this for a tbi? You can get a new sender from rockauto pretty cheap
