Author Topic: New from AZ  (Read 25033 times)
Offline bravo1616
New from AZ
« on: September 21, 2010, 06:04:18 pm »
I just bought this GMC truck as a project for me & my son, we have 3 years until he can drive it...good thing.
1982 GMC K1500 Sierra Classic 383 Stroker 4" Rough Country Lift
Re: New from AZ
« Reply #1 on: September 21, 2010, 06:37:15 pm »
Welcome to the site from NW Indiana
Offline fitz
Re: New from AZ
« Reply #2 on: September 21, 2010, 06:49:33 pm »
Welcome from Mass. Looks like a solid start to a father & son project.
Good luck with it.
Offline bravo1616
Re: New from AZ
« Reply #3 on: September 21, 2010, 09:45:30 pm »
Good luck with it.
Thanks but, I had to laugh, it's mother & son!
Offline fitz
Re: New from AZ
« Reply #4 on: September 21, 2010, 09:50:59 pm »
[/quote]
I'm impressed, hopefully this site can help you along the way.
Offline bravo1616
Re: New from AZ
« Reply #5 on: September 21, 2010, 10:55:05 pm »
[/quote]
I hope so too. So far we just started with making the truck safe to drive with seat belts & brakes, next is front end stuff.
Offline bravo1616
Re: New from AZ
« Reply #6 on: September 21, 2010, 11:18:57 pm »
oh, and we installed speakers - gotta have music. nothing great, just modified the 4x10 speaker plates and put in 5x7s that I had from my 82 S10 Blazer.
Offline Layne
Re: New from AZ
« Reply #7 on: September 21, 2010, 11:23:24 pm »
Welcome from Illinois
Offline bravo1616
Re: New from AZ
« Reply #8 on: September 22, 2010, 12:53:48 am »
Hey, can anyone tell me the difference between a drop-down steering arm and a lowering pitman arm? would you use both or one or the other? thanks.
Offline Old77
Re: New from AZ
« Reply #9 on: September 22, 2010, 08:12:50 am »
Welcome to the site and good luck on the father/son project! I hope to do something similar as my boys get older:) My 77 was a father/son project that we started back in 2003 but i was 26 rather than 13! :) It still meant a lot, though, and I will never get rid of that truck:)
www.chevygmcofkc.org
Offline jaredts
Re: New from AZ
« Reply #10 on: September 22, 2010, 08:38:38 am »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=15817.msg123676#msg123676
That post will identify the parts for you, but I'm not sure of the drop down or lowering part.  Sounds like parts for lowering or body lifts.  I've never had a 73-87 4x4 so I'm pretty weak on the front ends.
Old77--Mother/son.
Offline Old77
Re: New from AZ
« Reply #11 on: September 22, 2010, 08:45:48 am »
Old77--Mother/son.
My bad!! :) My point remains the same. He's going to have a blast working on that truck with you and it'll bond the two of you for life and bring your relationship even closer! :)
Offline bravo1616
Re: New from AZ
« Reply #12 on: September 22, 2010, 08:53:13 am »
hey jaredts, thanks for the link.
the parts I'm asking about are for steering, there is a 4 inch lift and the steering bumps and doesn't turn all the way to the right, which I read is common when there is a lift, but I've been getting mixed info as to which to change out, the lowering pitman arm or the drop down steering arm or is it both.
and thanks to everyone for the welcome posts.
Offline Grim 82
Re: New from AZ
« Reply #13 on: September 22, 2010, 10:19:30 am »
Theoretically, you can use one piece, or a combination of pieces to correct the angle. They make a drop pitman arm, a raised steering arm, or adjustable S-drag links. They also make spacers which lift the factory steering arm. So, if you need say 4" of correction, you could get a pitman with a 4" drop, a steering arm with 4" rise, or split the difference 2" each but then you would be buying two parts. I would probably get the corrected steering arm from any reputable suspension lift company that specifies for the amount of lift that you have. Welcome to the site.
http://www.jackit.com/steering/chevy_steering_corrections.htm
« Last Edit: September 22, 2010, 03:56:43 pm by Grim 82 »
Offline bravo1616
Re: New from AZ
« Reply #14 on: September 22, 2010, 01:13:16 pm »
Thanks Grim 82!
